Up to 20% off select tools
LG Phoenix 2 Front Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
62
All Time:
670
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you need to install a new front camera on your LG Phoenix 2, use this guide to disassemble and replace the damaged front camera. For this guide you will need a plastic opening tool and a Phillips #000 screwdriver head. These steps will be straightforward and easy to follow, but the pieces should be handled with care, so as to not damage or misplace any needed components.
    1. LG Phoenix 2 Front Camera Replacement, Front Camera: step 1, image 1 of 2 LG Phoenix 2 Front Camera Replacement, Front Camera: step 1, image 2 of 2
      • Insert a fingernail into the notch on the bottom right corner of the phone.
      • Remove the back cover off of the device.
      Ask FixBot
    2. LG Phoenix 2 Front Camera Replacement: step 2, image 1 of 1
      • Insert a fingernail into the notch under the battery.
      • Remove the battery.
      Ask FixBot
    3. LG Phoenix 2 Front Camera Replacement: step 3, image 1 of 2 LG Phoenix 2 Front Camera Replacement: step 3, image 2 of 2
      • Insert the opening tool under the bottom cover.
      • Pop off the bottom cover.
      Ask FixBot
    4. LG Phoenix 2 Front Camera Replacement: step 4, image 1 of 1
      • Remove eight 3mm screws using the Phillips #0 screwdriver.
      Ask FixBot
    5. LG Phoenix 2 Front Camera Replacement: step 5, image 1 of 2 LG Phoenix 2 Front Camera Replacement: step 5, image 2 of 2
      • Insert the opening tool in between the phone screen and the silver trim.
      • Pop off the silver trim.
      Ask FixBot
    6. LG Phoenix 2 Front Camera Replacement: step 6, image 1 of 2 LG Phoenix 2 Front Camera Replacement: step 6, image 2 of 2
      • Insert the opening tool under the bottom of the front camera connection to the motherboard.
      • Pop off the front camera.
      Ask FixBot
Author
with
Sarah Popp
395 Reputation
3 Guides authored
IUPUI, Team S7-G7, Wilson Fall 2018 Member of IUPUI, Team S7-G7, Wilson Fall 2018
IUPUI-WILSON-F18S7G7
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 62
All Time: 670
