LG Phoenix 2 Charge Port Replacement
    1. LG Phoenix 2 Charge Port Replacement, Battery: step 1, image 1 of 3 LG Phoenix 2 Charge Port Replacement, Battery: step 1, image 2 of 3 LG Phoenix 2 Charge Port Replacement, Battery: step 1, image 3 of 3
      • Place a fingernail in the notch at the bottom edge of the phone.
      • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
      Ask FixBot
    2. LG Phoenix 2 Charge Port Replacement: step 2, image 1 of 3 LG Phoenix 2 Charge Port Replacement: step 2, image 2 of 3 LG Phoenix 2 Charge Port Replacement: step 2, image 3 of 3
      • Place a fingernail in the notch at the bottom edge of the battery.
      • Pull the battery out.
      Ask FixBot
    1. LG Phoenix 2 Charge Port Replacement, Motherboard: step 3, image 1 of 2 LG Phoenix 2 Charge Port Replacement, Motherboard: step 3, image 2 of 2
      • Remove all nine of the 3.0mm screws on the back of the phone using a Phillips #0 screwdriver, including the one attaching the camera lens.
      Ask FixBot
    2. LG Phoenix 2 Charge Port Replacement: step 4, image 1 of 2 LG Phoenix 2 Charge Port Replacement: step 4, image 2 of 2
      • With the plastic opening tool, pry between the screen and the outer chrome edge to remove the bottom shield from the rest of the phone.
      Ask FixBot
    3. LG Phoenix 2 Charge Port Replacement: step 5, image 1 of 3 LG Phoenix 2 Charge Port Replacement: step 5, image 2 of 3 LG Phoenix 2 Charge Port Replacement: step 5, image 3 of 3
      • With a plastic opening tool, disconnect all three ribbon connectors from the motherboard: one for the front camera, one for the rear camera, and one for the screen.
      Ask FixBot
    4. LG Phoenix 2 Charge Port Replacement: step 6, image 1 of 3 LG Phoenix 2 Charge Port Replacement: step 6, image 2 of 3 LG Phoenix 2 Charge Port Replacement: step 6, image 3 of 3
      • Using a plastic opening tool, separate the motherboard from the back frame and remove it from the device.
      Ask FixBot
    1. LG Phoenix 2 Charge Port Replacement, Charge Port: step 7, image 1 of 2 LG Phoenix 2 Charge Port Replacement, Charge Port: step 7, image 2 of 2
      Ask FixBot
    2. LG Phoenix 2 Charge Port Replacement: step 8, image 1 of 3 LG Phoenix 2 Charge Port Replacement: step 8, image 2 of 3 LG Phoenix 2 Charge Port Replacement: step 8, image 3 of 3
      • Desolder the USB port from the motherboard and remove it from the device.
      Ask FixBot
3 other people completed this guide.
Alex Selsley
325 Reputation
2 Guides authored
IUPUI, Team S1-G1, Harley Fall 2019 Member of IUPUI, Team S1-G1, Harley Fall 2019
IUPUI-HARLEY-F19S1G1
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 70
All Time: 1,259
