Up to 20% off select tools
LG Phoenix 2 Battery Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
66
All Time:
2,192
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a battery in an LG Phoenix 2. A battery replacement may be needed if the phone loses charge faster than it did when it was new. A battery replacement may also be needed if the phone only works when it is plugged in and does not hold a charge at all.
The battery model used in this phone is a BL-46ZH battery.
    1. LG Phoenix 2 Battery Replacement, Battery: step 1, image 1 of 3 LG Phoenix 2 Battery Replacement, Battery: step 1, image 2 of 3 LG Phoenix 2 Battery Replacement, Battery: step 1, image 3 of 3
      • Place a fingernail in the notch at the bottom edge of the phone.
      • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
      Ask FixBot
    2. LG Phoenix 2 Battery Replacement: step 2, image 1 of 3 LG Phoenix 2 Battery Replacement: step 2, image 2 of 3 LG Phoenix 2 Battery Replacement: step 2, image 3 of 3
      • Place a fingernail in the notch at the bottom edge of the battery.
      • Pull the battery out.
      Ask FixBot
3 other people completed this guide.
Author
with
Esteban Ruibal
705 Reputation
5 Guides authored
USF Tampa, Team S2-G2, Eyestone Spring 2018 Member of USF Tampa, Team S2-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 66
All Time: 2,192
