LG Optimus V Speaker Replacement
    1. LG Optimus V Speaker Replacement, Battery: step 1, image 1 of 1
      • Turn the LG Optimus V over, so that the back cover is facing upward.
      Ask FixBot
    2. LG Optimus V Speaker Replacement: step 2, image 1 of 1
      • Locate the opening above the camera.
      • Use a spudger to detach the back cover.
      Ask FixBot
    3. LG Optimus V Speaker Replacement: step 3, image 1 of 3 LG Optimus V Speaker Replacement: step 3, image 2 of 3 LG Optimus V Speaker Replacement: step 3, image 3 of 3
      • Gently remove the battery with your spudger.
      Ask FixBot
    1. LG Optimus V Speaker Replacement, Camera: step 4, image 1 of 2 LG Optimus V Speaker Replacement, Camera: step 4, image 2 of 2
      • Remove the six screws on the silver casing.
      • Use the plastic opening tool to remove the silver casing.
      Ask FixBot
    2. LG Optimus V Speaker Replacement: step 5, image 1 of 3 LG Optimus V Speaker Replacement: step 5, image 2 of 3 LG Optimus V Speaker Replacement: step 5, image 3 of 3
      • Use a plastic opening tool to remove each area holding the parts together.
      Ask FixBot
    3. LG Optimus V Speaker Replacement: step 6, image 1 of 2 LG Optimus V Speaker Replacement: step 6, image 2 of 2
      • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
      • Use a plastic opening tool to pry off the camera.
      Ask FixBot
    1. LG Optimus V Speaker Replacement, Speaker: step 7, image 1 of 1
      • This is the area that holds the speaker.
      Ask FixBot
    2. LG Optimus V Speaker Replacement: step 8, image 1 of 2 LG Optimus V Speaker Replacement: step 8, image 2 of 2
      • To fix the speaker, use a soldering iron to heat up the two areas where the wires connect to the motherboard. Then, remove the old speaker and replace it with a new one by soldering it back onto the same areas.
      • Once you’re done, your speaker should be working properly again.
      Ask FixBot
Joseph Pasquantonio
683 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Shastany Fall 2013 Member of UMass Dartmouth, Team 1-2, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 93
All Time: 1,269
