LG Optimus V Antenna Replacement
    1. LG Optimus V Antenna Replacement, Battery: step 1, image 1 of 1
      • Turn the LG Optimus V over, so that the back cover is facing upward.
      Ask FixBot
    2. LG Optimus V Antenna Replacement: step 2, image 1 of 1
      • Locate the opening above the camera.
      • Use a spudger to detach the back cover.
      Ask FixBot
    3. LG Optimus V Antenna Replacement: step 3, image 1 of 3 LG Optimus V Antenna Replacement: step 3, image 2 of 3 LG Optimus V Antenna Replacement: step 3, image 3 of 3
      • Gently remove the battery with your spudger.
      Ask FixBot
    1. LG Optimus V Antenna Replacement, Camera: step 4, image 1 of 2 LG Optimus V Antenna Replacement, Camera: step 4, image 2 of 2
      • Remove the six screws on the silver casing.
      • Use the plastic opening tool to remove the silver casing.
      Ask FixBot
    2. LG Optimus V Antenna Replacement: step 5, image 1 of 3 LG Optimus V Antenna Replacement: step 5, image 2 of 3 LG Optimus V Antenna Replacement: step 5, image 3 of 3
      • Use a plastic opening tool to remove each area holding the parts together.
      Ask FixBot
    3. LG Optimus V Antenna Replacement: step 6, image 1 of 2 LG Optimus V Antenna Replacement: step 6, image 2 of 2
      • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
      • Use a plastic opening tool to pry off the camera.
      Ask FixBot
    1. LG Optimus V Antenna Replacement, Antenna: step 7, image 1 of 2 LG Optimus V Antenna Replacement, Antenna: step 7, image 2 of 2
      • Use a soldering iron to desolder the connections attaching the the antenna to the motherboard.
      Ask FixBot
    2. LG Optimus V Antenna Replacement: step 8, image 1 of 1
      • Solder off the antenna, and solder on the new one. The antenna is now replaced.
      Ask FixBot
3 other people completed this guide.
Joseph Pasquantonio
683 Reputation
5 Guides authored
UMass Dartmouth, Team 1-2, Shastany Fall 2013 Member of UMass Dartmouth, Team 1-2, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 111
All Time: 2,857
