LG Optimus T Motherboard Replacement
    1. LG Optimus T Motherboard Replacement, Motherboard: step 1, image 1 of 3 LG Optimus T Motherboard Replacement, Motherboard: step 1, image 2 of 3 LG Optimus T Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
      • Using a prying device, such as a plastic opening tool, remove the phone’s back cover. At the top of the phone, there’s an indentation to put the Spudger into to pop the case off
      Ask FixBot
    2. LG Optimus T Motherboard Replacement: step 2, image 1 of 1
      • Remove the battery. There’s an indentation to the left of the camera lens to pull up on the battery with your finger
      Ask FixBot
    3. LG Optimus T Motherboard Replacement: step 3, image 1 of 1
      • Use a J0 screwdriver to remove the six 4.5mm screws.
      Ask FixBot
    4. LG Optimus T Motherboard Replacement: step 4, image 1 of 2 LG Optimus T Motherboard Replacement: step 4, image 2 of 2
      • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic opening tool fails
      • Remove interior case. Insert the spudger into the indentations at the top, or bottom of the phone to pry off the interior case.
      Ask FixBot
    5. LG Optimus T Motherboard Replacement: step 5, image 1 of 1
      • Pull up on connector tab
      Ask FixBot
    6. LG Optimus T Motherboard Replacement: step 6, image 1 of 2 LG Optimus T Motherboard Replacement: step 6, image 2 of 2
      • Remove SD card mount. Insert the plastic opening tool on the right side to pop off
      Ask FixBot
    7. LG Optimus T Motherboard Replacement: step 7, image 1 of 2 LG Optimus T Motherboard Replacement: step 7, image 2 of 2
      • Remove metal panel
      • There are four retaining points to insert plastic opening tool and pop off panel
      Ask FixBot
    8. LG Optimus T Motherboard Replacement: step 8, image 1 of 1
      • Use a J0 screwdriver to remove the two 1.8mm screws from charging port. (Charging port and motherboard are connected.)
      • Remove motherboard
      Ask FixBot
stacey
219 Reputation
2 Guides authored
Ohio State, Team 1-3, Wilder Spring 2017 Member of Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 90
All Time: 655
