LG Optimus T Camera and Camera Mount Replacement
    1. LG Optimus T Camera and Camera Mount Replacement, Camera: step 1, image 1 of 2 LG Optimus T Camera and Camera Mount Replacement, Camera: step 1, image 2 of 2
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
      • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
      Ask FixBot
    2. LG Optimus T Camera and Camera Mount Replacement: step 2, image 1 of 1
      • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
      Ask FixBot
    3. LG Optimus T Camera and Camera Mount Replacement: step 3, image 1 of 1
      • Use a J0 screwdriver to remove the 6 highlighted screws
      Ask FixBot
    4. LG Optimus T Camera and Camera Mount Replacement: step 4, image 1 of 2 LG Optimus T Camera and Camera Mount Replacement: step 4, image 2 of 2
      • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
      • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
      Ask FixBot
    5. LG Optimus T Camera and Camera Mount Replacement: step 5, image 1 of 1
      • Unhook the connector tab
      Ask FixBot
    6. LG Optimus T Camera and Camera Mount Replacement: step 6, image 1 of 1
      • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
      Ask FixBot
    7. LG Optimus T Camera and Camera Mount Replacement: step 7, image 1 of 2 LG Optimus T Camera and Camera Mount Replacement: step 7, image 2 of 2
      • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
      Ask FixBot
    8. LG Optimus T Camera and Camera Mount Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • disconnect camera connector from motherboard by spudger
      • Once disconnected, remove camera using tweezers
      Ask FixBot
stacey
219 Reputation
2 Guides authored
Ohio State, Team 1-3, Wilder Spring 2017 Member of Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 92
All Time: 444
