LG Optimus L90 Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. LG Optimus L90 Battery Replacement, Battery: step 1, image 1 of 3 LG Optimus L90 Battery Replacement, Battery: step 1, image 2 of 3 LG Optimus L90 Battery Replacement, Battery: step 1, image 3 of 3
    • Carefully slide an opening pick between the the rear cover and the body of the phone.
    • Using the pick, separate the cover from the back of the phone.
    • Remove the rear cover.
  2. LG Optimus L90 Battery Replacement: step 2, image 1 of 2 LG Optimus L90 Battery Replacement: step 2, image 2 of 2
    • Insert a plastic opening tool int o the small recess at the bottom of the battery.
    • Use the plastic opening tool to lift up the bottom of the battery.
    • Remove the battery from the phone.
Once you have placed your phone case back on your device, it should be fully functional.
Julie
246 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 575
