LG Optimus L9 P769 Motherboard Replacement
    1. LG Optimus L9 P769 Motherboard Replacement, Motherboard: step 1, image 1 of 3 LG Optimus L9 P769 Motherboard Replacement, Motherboard: step 1, image 2 of 3 LG Optimus L9 P769 Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Start by placing the device face down and remove the back cove.
      • Remove the battery from the phone by lifting it using your finger or the prying tool
      Ask FixBot
    2. LG Optimus L9 P769 Motherboard Replacement: step 2, image 1 of 3 LG Optimus L9 P769 Motherboard Replacement: step 2, image 2 of 3 LG Optimus L9 P769 Motherboard Replacement: step 2, image 3 of 3
      • Remove all 10 of the 4.5mm Phillips screws that holds the back frame to the case of the phone
      • Using a small plastic prying tool, carefully remove the back frame by prying on the sides of the device.
      • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
      Ask FixBot
    3. LG Optimus L9 P769 Motherboard Replacement: step 3, image 1 of 3 LG Optimus L9 P769 Motherboard Replacement: step 3, image 2 of 3 LG Optimus L9 P769 Motherboard Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Using tweezers, pinch the sides of the antenna node and pull straight up.
      • Using a small prying tool, carefully remove the ribbon cables attached to the motherboard.
      Ask FixBot
    4. LG Optimus L9 P769 Motherboard Replacement: step 4, image 1 of 2 LG Optimus L9 P769 Motherboard Replacement: step 4, image 2 of 2
      • Using a spudger or small prying tool, lift up the motherboard from the chassis of the device.
      Ask FixBot
2 other people completed this guide.
Ammar Rizal
225 Reputation
2 Guides authored
IUPUI, Team S2-G1, Harley Spring 2017 Member of IUPUI, Team S2-G1, Harley Spring 2017
IUPUI-HARLEY-S17S2G1
4 Members
69 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 801
