LG Optimus L7 P705 Display Replacement
    1. LG Optimus L7 P705 Display Replacement, Display: step 1, image 1 of 2 LG Optimus L7 P705 Display Replacement, Display: step 1, image 2 of 2
      • Use a plastic opening tool to gently pry the back cover away from the phone by inserting it into the seam around the edges.
      • Once the cover is off, remove the battery and SIM card.
      Ask FixBot
    2. LG Optimus L7 P705 Display Replacement: step 2, image 1 of 1
      • Using a Phillips #000 screwdriver, remove the twelve 3mm screws around the frame, including those near the SIM and SD card slots.
      Ask FixBot
    3. LG Optimus L7 P705 Display Replacement: step 3, image 1 of 1
      • Carefully remove the bottom plastic plate located around the charging port area.
      Ask FixBot
    4. LG Optimus L7 P705 Display Replacement: step 4, image 1 of 2 LG Optimus L7 P705 Display Replacement: step 4, image 2 of 2
      • Insert a plastic opening tool along the seam of the phone’s frame and gently apply pressure to lift off the midframe cover.
      Ask FixBot
    5. LG Optimus L7 P705 Display Replacement: step 5, image 1 of 2 LG Optimus L7 P705 Display Replacement: step 5, image 2 of 2
      • Flip the phone over so the screen is facing up.
      • Carefully lift and remove the glass screen (display) from the front of the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
8 other people completed this guide.
Craig Lashley
307 Reputation
1 Guide authored
USF Tampa, Team 9-1, Leahy Fall 2014 Member of USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 Members
60 Guides authored
2 Guide Comments
Great tutorial as always on ifixit. Just be mindful of the top clip holding the glass bevel as it can be tricky and is close to circuitry.
Sooty - Reply Share
Im miles i great this ifixit i'm beginner
Omair Sarip - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 103
All Time: 5,873
