LG Optimus G Pro Speaker Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
95
All Time:
2,056
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Make sure that have completed the prerequisite guides to remove the inner cover, so that the speaker may be accessed. After that, this guide will show you how to replace your speaker.
Tools
    1. LG Optimus G Pro Speaker Replacement, Remove Back Cover.: step 1, image 1 of 1
      • Make sure before you begin working on your device, that the device is not charging.
      • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
      Ask FixBot
    2. LG Optimus G Pro Speaker Replacement, Remove the Battery.: step 2, image 1 of 1
      • Once you have properly removed the outer casing, the back should look as so.
      • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
      • Once the battery is removed you may safely proceed to the next step.
      Ask FixBot
    1. LG Optimus G Pro Speaker Replacement, Screw Removal: step 3, image 1 of 2 LG Optimus G Pro Speaker Replacement, Screw Removal: step 3, image 2 of 2
      • Make sure you remove the battery first. You will see that there are 14 screws on the back of the inner case. Use the Phillips head screwdriver to remove each of the screws, make sure to put the screws in a safe place where they will not get lost.
      Ask FixBot
    2. LG Optimus G Pro Speaker Replacement, Remove Cover: step 4, image 1 of 1
      • Once you have removed all the screws, you can begin removing the inside cover.
      • Insert the opening tool using a sliding motion into one of the corners and move it along the edges of the inside cover. This will loosen the edges and the inside cover will pry apart from the shell.
      Ask FixBot
    3. LG Optimus G Pro Speaker Replacement, Completion: step 5, image 1 of 1
      • The inner cover is now removed, you now have access to the many parts on the inside of the phone.
      Ask FixBot
    1. LG Optimus G Pro Speaker Replacement, Speaker Removal.: step 6, image 1 of 2 LG Optimus G Pro Speaker Replacement, Speaker Removal.: step 6, image 2 of 2
      • The inner side of the inside cover houses the speaker module.
      • Use the plastic opening tool to pry the connection between the inner side and the speaker.
      Ask FixBot
    2. LG Optimus G Pro Speaker Replacement, Completetion: step 7, image 1 of 1
      • You now have removed the speaker for an easy replacement.
      Ask FixBot
2 other people completed this guide.
Wesley Pate
1,641 Reputation
7 Guides authored
USF Tampa, Team 15-5, Remmell Fall 2014 Member of USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 95
All Time: 2,056
