Up to 20% off select tools
LG Optimus G Pro Midframe Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
97
All Time:
2,612
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This follows the battery replacement guide, so make sure to do that first. This guide will help you continue into future repair guides and act as a pre-requisite for future steps on the device page.
    1. LG Optimus G Pro Midframe Replacement, Remove Back Cover.: step 1, image 1 of 1
      • Make sure before you begin working on your device, that the device is not charging.
      • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
      Ask FixBot
    2. LG Optimus G Pro Midframe Replacement, Remove the Battery.: step 2, image 1 of 1
      • Once you have properly removed the outer casing, the back should look as so.
      • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
      • Once the battery is removed you may safely proceed to the next step.
      Ask FixBot
    1. LG Optimus G Pro Midframe Replacement, Screw Removal: step 3, image 1 of 2 LG Optimus G Pro Midframe Replacement, Screw Removal: step 3, image 2 of 2
      • Make sure you remove the battery first. You will see that there are 14 screws on the back of the inner case. Use the Phillips head screwdriver to remove each of the screws, make sure to put the screws in a safe place where they will not get lost.
      Ask FixBot
    2. LG Optimus G Pro Midframe Replacement, Remove Cover: step 4, image 1 of 1
      • Once you have removed all the screws, you can begin removing the inside cover.
      • Insert the opening tool using a sliding motion into one of the corners and move it along the edges of the inside cover. This will loosen the edges and the inside cover will pry apart from the shell.
      Ask FixBot
    3. LG Optimus G Pro Midframe Replacement, Completion: step 5, image 1 of 1
      • The inner cover is now removed, you now have access to the many parts on the inside of the phone.
      Ask FixBot
3 other people completed this guide.
Author
with
Wesley Pate
1,641 Reputation
7 Guides authored
USF Tampa, Team 15-5, Remmell Fall 2014 Member of USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 97
All Time: 2,612
