LG Optimus G Pro Battery Replacement
    1. LG Optimus G Pro Battery Replacement, Remove Back Cover.: step 1, image 1 of 1
      • Make sure before you begin working on your device, that the device is not charging.
      • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
      Ask FixBot
    2. LG Optimus G Pro Battery Replacement, Remove the Battery.: step 2, image 1 of 1
      • Once you have properly removed the outer casing, the back should look as so.
      • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
      • Once the battery is removed you may safely proceed to the next step.
      Ask FixBot
10 other people completed this guide.
Wesley Pate
1,641 Reputation
7 Guides authored
USF Tampa, Team 15-5, Remmell Fall 2014 Member of USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 102
All Time: 3,730
