Up to 20% off select tools
LG Optimus F60 Front Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
60
All Time:
683
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
This guide will take you through the process of replacing the front camera in an LG Optimus F60. This task should take about 7minutes to complete.
    1. LG Optimus F60 Front Camera Replacement, Battery: step 1, image 1 of 3 LG Optimus F60 Front Camera Replacement, Battery: step 1, image 2 of 3 LG Optimus F60 Front Camera Replacement, Battery: step 1, image 3 of 3
      • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
      • Pry or lift up on the indent with the opening tool.
      • Remove the back panel.
      Ask FixBot
    2. LG Optimus F60 Front Camera Replacement: step 2, image 1 of 3 LG Optimus F60 Front Camera Replacement: step 2, image 2 of 3 LG Optimus F60 Front Camera Replacement: step 2, image 3 of 3
      • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
      • Pry upwards or lift with your finger and remove battery.
      Ask FixBot
    1. LG Optimus F60 Front Camera Replacement, Front Camera: step 3, image 1 of 2 LG Optimus F60 Front Camera Replacement, Front Camera: step 3, image 2 of 2
      • Use the phillips #000 Screwdriver to unscrew eight 4mm screws.
      Ask FixBot
    2. LG Optimus F60 Front Camera Replacement: step 4, image 1 of 2 LG Optimus F60 Front Camera Replacement: step 4, image 2 of 2
      • Insert the plastic opening tool in the indentation marked by the red square.
      • Pry the plastic opening tool upwards to release the lower back panel.
      • Remove the lower back panel from the device.
      Ask FixBot
    3. LG Optimus F60 Front Camera Replacement: step 5, image 1 of 3 LG Optimus F60 Front Camera Replacement: step 5, image 2 of 3 LG Optimus F60 Front Camera Replacement: step 5, image 3 of 3
      • Continue moving plastic opening tool around device until back panel is loose enough to remove.
      Ask FixBot
    4. LG Optimus F60 Front Camera Replacement: step 6, image 1 of 3 LG Optimus F60 Front Camera Replacement: step 6, image 2 of 3 LG Optimus F60 Front Camera Replacement: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Locate the digitizer connection on the lower left hand side of the device.
      • Use the tweezers to lift up and gently remove the connector.
      Ask FixBot
    5. LG Optimus F60 Front Camera Replacement: step 7, image 1 of 3 LG Optimus F60 Front Camera Replacement: step 7, image 2 of 3 LG Optimus F60 Front Camera Replacement: step 7, image 3 of 3
      • Locate the front camera on the upper left hand side of the device. The camera is marked in red.
      • Use the tweezers to remove the front camera from the connector marked in orange.
      • Remove and replace front camera.
      Ask FixBot
Author
with
Austin Johnson
171 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 60
All Time: 683
