LG Optimus F3 Motherboard Replacement
    1. LG Optimus F3 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Turn the device so that the back faces up.
      • It is easiest to open the case near the charging port located at the bottom of the phone.
      • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
      Ask FixBot
    2. LG Optimus F3 Motherboard Replacement: step 2, image 1 of 1
      • With back case removed, the battery is visible. The battery is the large square object.
      • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
      Ask FixBot
    3. LG Optimus F3 Motherboard Replacement: step 3, image 1 of 1
      • Remove 10 1.0 mm screws located on the back of the device.
      • Refer to the outlined locations in the image for the screws.
      Ask FixBot
    4. LG Optimus F3 Motherboard Replacement: step 4, image 1 of 1
      • Use the plastic opening tool to separate the inner case from the device.
      • Wedge the plastic opening tool between the case.
      • Wiggle the tool and use leverage to pry the case apart.
      Ask FixBot
    5. LG Optimus F3 Motherboard Replacement: step 5, image 1 of 1
      • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
      • Use the plastic opening tool to separate the camera from the motherboard.
      • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
      Ask FixBot
    6. LG Optimus F3 Motherboard Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to disconnect and remove the rear facing camera.
      Ask FixBot
    7. LG Optimus F3 Motherboard Replacement: step 7, image 1 of 1
      • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
      • Note that the sim card and the memory card connector are one unit.
      • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
      Ask FixBot
    8. LG Optimus F3 Motherboard Replacement: step 8, image 1 of 1
      • Use the plastic opening tool to remove the charging port unit.
      • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
      Ask FixBot
    9. LG Optimus F3 Motherboard Replacement: step 9, image 1 of 1
      • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
      • The motherboard is an L-shaped unit above and to the left of the battery encasement.
      • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
      Ask FixBot
3 other people completed this guide.
Battsooj Bayarsaikhan
101 Reputation
1 Guide authored
UMass Dartmouth, Team 1-5, Miles Fall 2015 Member of UMass Dartmouth, Team 1-5, Miles Fall 2015
UMASSD-MILES-F15S1G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 100
All Time: 1,209
