Up to 20% off select tools
LG Optimus F3 MicroSD Card Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
87
All Time:
693
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 7 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the SD card exceeds its memory capacity, use this guide to replace the SD card
    1. LG Optimus F3 MicroSD Card Replacement, Removing the Back Cover: step 1, image 1 of 1
      • Remove back cover of the LG VM720
      Ask FixBot
    2. LG Optimus F3 MicroSD Card Replacement, Locating the SD Card: step 2, image 1 of 1
      • When the back cover is completely removed, locate the sim card slot. It should be to the right of the camera and it is clearly labeled “Micro SD”
      Ask FixBot
    3. LG Optimus F3 MicroSD Card Replacement, Removing the SD Card: step 3, image 1 of 1
      • Remove the SD card in the opposite direction of the battery.
      Ask FixBot
    4. LG Optimus F3 MicroSD Card Replacement, Replacing the SD Card: step 4, image 1 of 1
      • You should now be able to put in a new SD card in that same slot.
      Ask FixBot
2 other people completed this guide.
Author
with
Basil George
280 Reputation
2 Guides authored
USF Tampa, Team 7-3, Leahy Fall 2014 Member of USF Tampa, Team 7-3, Leahy Fall 2014
USFT-LEAHY-F14S7G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 87
All Time: 693
