Up to 20% off select tools
LG Optimus Dynamic II L39C Screen Replacement
Views: 3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
93
All Time:
2,974
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
For trouble with touch feedback or if your screen is cracked and you want to replace it.
    1. LG Optimus Dynamic II L39C Screen Replacement, Remove the back case: step 1, image 1 of 2 LG Optimus Dynamic II L39C Screen Replacement, Remove the back case: step 1, image 2 of 2
      • Make sure not to push the tool into the USB port. Doing so may cause damage to your phone.
      • Hold the blue plastic opening tool at the edge of the USB opening. Push down and pry the case off the phone gently.
      Ask FixBot
    2. LG Optimus Dynamic II L39C Screen Replacement, Remove the Battery: step 2, image 1 of 1
      • Lift the battery out of the phone and replace with your new one.
      Ask FixBot
    1. LG Optimus Dynamic II L39C Screen Replacement, Remove the SD Card: step 3, image 1 of 1
      • Grab the end of the SD Card and pull it out of the phone.
      Ask FixBot
    2. LG Optimus Dynamic II L39C Screen Replacement, Remove the screws from the midframe: step 4, image 1 of 2 LG Optimus Dynamic II L39C Screen Replacement, Remove the screws from the midframe: step 4, image 2 of 2
      • Use the PH #000 screwdriver to remove the six screws from the midframe
      Ask FixBot
    3. LG Optimus Dynamic II L39C Screen Replacement, Remove the midframe: step 5, image 1 of 2 LG Optimus Dynamic II L39C Screen Replacement, Remove the midframe: step 5, image 2 of 2
      • Using the plastic opening tool, work gently to go around the perimeter of the phone and remove the midframe.
      Ask FixBot
    4. LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: step 6, image 1 of 3 LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: step 6, image 2 of 3 LG Optimus Dynamic II L39C Screen Replacement, Disconnect the screen from the motherboard: step 6, image 3 of 3
      • Use the plastic opening tool to disconnect the small orange tab from the motherboard.
      • Next disconnect the silver tab slightly above where the orange tab was.
      Ask FixBot
    5. LG Optimus Dynamic II L39C Screen Replacement, Separate the screen and motherboard: step 7, image 1 of 1
      • Gently feed the orange and silver tabbed ribbons through the hole in the motherboard and the screen will be free.
      Ask FixBot
6 other people completed this guide.
Author
with
Patrick Barron
158 Reputation
1 Guide authored
USF Tampa, Team 14-3, Leahy Fall 2014 Member of USF Tampa, Team 14-3, Leahy Fall 2014
USFT-LEAHY-F14S14G3
4 Members
36 Guides authored
1 Guide Comment
My screen is black but everything else works (even the touch screen -- I can use it to answer calls). I used this guide to change the screens from a working phone - but my screen is still black! Anyone have any ideas?
Jack - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 93
All Time: 2,974
