LG Optimus 3D Motherboard Replacement
    1. LG Optimus 3D Motherboard Replacement, Back Cover Removal: step 1, image 1 of 2 LG Optimus 3D Motherboard Replacement, Back Cover Removal: step 1, image 2 of 2
      • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
      Ask FixBot
    2. LG Optimus 3D Motherboard Replacement, Battery Removal: step 2, image 1 of 3 LG Optimus 3D Motherboard Replacement, Battery Removal: step 2, image 2 of 3 LG Optimus 3D Motherboard Replacement, Battery Removal: step 2, image 3 of 3
      • The battery is the large black rectangle towards the bottom half of the phone.
      • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
      Ask FixBot
    1. LG Optimus 3D Motherboard Replacement, Screw Removal: step 3, image 1 of 2 LG Optimus 3D Motherboard Replacement, Screw Removal: step 3, image 2 of 2
      • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
      • 5.5mm length PH00 screws
      • 4mm length PH00 screws
      Ask FixBot
    2. LG Optimus 3D Motherboard Replacement, Bottom Cover Removal: step 4, image 1 of 2 LG Optimus 3D Motherboard Replacement, Bottom Cover Removal: step 4, image 2 of 2
      • Gently pull down on the bottom cover to remove it.
      Ask FixBot
    3. LG Optimus 3D Motherboard Replacement, Mid-Cover Bezel Removal: step 5, image 1 of 3 LG Optimus 3D Motherboard Replacement, Mid-Cover Bezel Removal: step 5, image 2 of 3 LG Optimus 3D Motherboard Replacement, Mid-Cover Bezel Removal: step 5, image 3 of 3
      • Using a plastic opening tool, gently pry around the perimeter of the device.
      • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
      • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
      Ask FixBot
    4. LG Optimus 3D Motherboard Replacement, Ribbon Cable Disconnection: step 6, image 1 of 2 LG Optimus 3D Motherboard Replacement, Ribbon Cable Disconnection: step 6, image 2 of 2
      • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
      Ask FixBot
    5. LG Optimus 3D Motherboard Replacement, Adhesive Loosening: step 7, image 1 of 1
      • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
      • Evenly heat the device in short intervals for about one minute.
      • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
      Ask FixBot
    6. LG Optimus 3D Motherboard Replacement, SD/SIM Card Board Removal: step 8, image 1 of 3 LG Optimus 3D Motherboard Replacement, SD/SIM Card Board Removal: step 8, image 2 of 3 LG Optimus 3D Motherboard Replacement, SD/SIM Card Board Removal: step 8, image 3 of 3
      • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
      • If the board is too difficult to separate than more heating may be required.
      Ask FixBot
    1. LG Optimus 3D Motherboard Replacement, Disconnect Ribbon Cables: step 9, image 1 of 2 LG Optimus 3D Motherboard Replacement, Disconnect Ribbon Cables: step 9, image 2 of 2
      • Using a spudger or plastic opening tool, gently lift the ribbon cables connected to the motherboard.
      • The button tabs, highlighted in orange, are held in with a light adhesive. Gently lift them out of the body of the phone with a spudger.
      Ask FixBot
    2. LG Optimus 3D Motherboard Replacement, Disconnect Antenna: step 10, image 1 of 2 LG Optimus 3D Motherboard Replacement, Disconnect Antenna: step 10, image 2 of 2
      • Remove the antenna cable by disconnecting both ends.
      • One end connects to the motherboard and the other connects near bottom of the phone.
      Ask FixBot
    3. LG Optimus 3D Motherboard Replacement, Remove Motherboard: step 11, image 1 of 2 LG Optimus 3D Motherboard Replacement, Remove Motherboard: step 11, image 2 of 2
      • Using a spudger gently lift the motherboard assembly out of the case.
      • Make sure the motherboard does not get snagged on the camera's ribbon cable.
      Ask FixBot
3 other people completed this guide.
Dale Pearson
784 Reputation
6 Guides authored
USF Tampa, Team 10-6, Brown Fall 2014 Member of USF Tampa, Team 10-6, Brown Fall 2014
USFT-BROWN-F14S10G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 108
All Time: 2,028
