Up to 20% off select tools
LG Neon II Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
92
All Time:
996
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
Introduction
Go to step 1 ↓
The LG Neon II GW370, a cell phone released in 2010, is complete with a camera, music player, and slide out QWERTY keyboard. It comes in a variety of colors, the most common being blue, green, orange, red, and black.
    1. LG Neon II Camera Replacement, Battery: step 1, image 1 of 1
      • To gain access to the phone’s speaker, grip the phone firmly in an inverted position with the back of the unit facing up and the LG insignia positioned away from you.
      • Using both hands as support, use your thumbs to gently guide the rear housing away and in the direction of the arrow.
      Ask FixBot
    2. LG Neon II Camera Replacement: step 2, image 1 of 1
      • After removing the phone’s back-panel, securely cushion the front of the phone on a soft surface such as a cloth or your hand.
      • Gently insert a spudger under the lip of the battery, preferably the lip away from the camera eye.
      • Gently pry the battery out of its seated position.
      Ask FixBot
    1. LG Neon II Camera Replacement, Button Board: step 3, image 1 of 1
      • To separate the button board/circuit module from the phone main frame, firmly, but gently, unscrew (counter-clockwise) the seven outside 4 mm screws along the rear outside rim of the main body.
      • Hold the phone securely.
      • Be sure to use the appropriate Philips #0 screw driver for the job. Not using the appropriate tool could damage the mounting screws.
      Ask FixBot
    2. LG Neon II Camera Replacement: step 4, image 1 of 1
      • Locate the lifted portion of plastic on the bottom end of the phone near the charger.
      • Slide the plastic opening tool underneath this lip, and gently pry the black plastic cover off.
      • Use the appropriate plastic pry tool to avoid circuit board damage.
      • There are three buttons around the outside of the phone that will fall out when you remove the plastic cover.
      Ask FixBot
    3. LG Neon II Camera Replacement: step 5, image 1 of 1
      • Loosen the two captive screws on the metal plate near the center of the phone using the Phillips #0 Screwdriver.
      • The screws will remain captive in the metal plate—do not attempt to remove them after they're loosened.
      Ask FixBot
    4. LG Neon II Camera Replacement: step 6, image 1 of 2 LG Neon II Camera Replacement: step 6, image 2 of 2
      • Using the plastic opening tool, gently pry the circuit board from the phone.
      • You may need to pry the circuit board in multiple locations to fully loosen it from the phone.
      • The underside of the circuit board is attached to the phone by some black tape. You will not be able to fully remove the circuit board, but you will be able to access the keyboard buttons located on the underside of the circuit board.
      • The partially separated circuit board may be attached to the main button area by factory adhesive/tape. If so, use a soft padded surface to rest the mother board on. Your work area will still be accessible without separating the two units.
      Ask FixBot
    1. LG Neon II Camera Replacement, Camera: step 7, image 1 of 2 LG Neon II Camera Replacement, Camera: step 7, image 2 of 2
      • Use the spudger to detach the metal rectangle from the keyboard panel.
      • The phone is now in two halves and the camera is visible.
      Ask FixBot
    2. LG Neon II Camera Replacement: step 8, image 1 of 2 LG Neon II Camera Replacement: step 8, image 2 of 2
      • Using the spudger, gently pry the black cover from around the camera.
      • The black cover should be opened up but not detached.
      Ask FixBot
    3. LG Neon II Camera Replacement: step 9, image 1 of 2 LG Neon II Camera Replacement: step 9, image 2 of 2
      • Using the plastic opening tool, gently pry under the four metal edges around the camera to loosen it from the phone.
      • Once the camera is loose it can be removed from the phone and replaced with a new one.
      Ask FixBot
Author
with
Sara
65 Reputation
5 Guides authored
Cal Poly, Team 1-6, Propen Fall 2012 Member of Cal Poly, Team 1-6, Propen Fall 2012
CPSU-PROPEN-F12S1G6
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 92
All Time: 996
