LG Neon GT 365 Speaker Replacement
    1. LG Neon GT 365 Speaker Replacement, Speaker: step 1, image 1 of 2 LG Neon GT 365 Speaker Replacement, Speaker: step 1, image 2 of 2
      • With one hand, push the rectangular button located on the back top-side of the phone.
      • With your other hand, remove the rear cover.
      Ask FixBot
    2. LG Neon GT 365 Speaker Replacement: step 2, image 1 of 1
      • Remove 5 screws, 1 from each corner of the phone and 1 from the center-right of the phone.
      Ask FixBot
    3. LG Neon GT 365 Speaker Replacement: step 3, image 1 of 2 LG Neon GT 365 Speaker Replacement: step 3, image 2 of 2
      • Pull off the rear casing, using an opening tool.
      • The volume buttons may fall out.
      Ask FixBot
    4. LG Neon GT 365 Speaker Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Once you have removed the rear casing flip it over to see a small circular metal piece with 2 gold springs sticking out of the bottom. That is the speaker.
      • Opposite the 2 small gold springs there will be a small black tab attached to the speaker sitting in a groove. Using tweezers or a small tipped screwdriver lift up on the tab to pop the speaker out.
      Ask FixBot
    5. LG Neon GT 365 Speaker Replacement: step 5, image 1 of 1
      • Replace the broken speaker with a new one (make sure to line up the tab with the groove). Push firmly into place.
      Ask FixBot
kristie
538 Reputation
5 Guides authored
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 Member of UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G1
4 Members
45 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 26
All Time: 591
