LG Neon GT 365 Screen Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
85
All Time:
1,480
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
Is your LG Neon GT 365 screen cracked, unresponsive, or displaying glitches? If so, you’re not alone. Screen damage is one of the most common phone issues, often caused by accidental drops or impact. This guide is here to help you fix these problems on your own, saving time and money on professional repairs.
By replacing the screen, you'll likely resolve issues such as touch sensitivity problems, display glitches, dead pixels, or complete unresponsiveness.
Tools
    1. LG Neon GT 365 Screen Replacement, Screen: step 1, image 1 of 1
      • With one hand stabilizing the phone, the other pushes the rectangular button located on the back topside of the phone.
      Ask FixBot
    2. LG Neon GT 365 Screen Replacement: step 2, image 1 of 1
      • With your other hand, remove the rear cover.
      Ask FixBot
    3. LG Neon GT 365 Screen Replacement: step 3, image 1 of 1
      • Using the appropriate bit from your 64 bit kit unscrew the red circled small black screws securing the back cover and internal components.
      • A screw may be covered by the slide spring. If so, move the slide spring to the side to access the screw.
      Ask FixBot
    4. LG Neon GT 365 Screen Replacement: step 4, image 1 of 2 LG Neon GT 365 Screen Replacement: step 4, image 2 of 2
      • Use the popping iFixit opening tool to go around the seam of the phone and slowly pull off the slide panel, making sure the ribbon connector does not get caught.
      Ask FixBot
    5. LG Neon GT 365 Screen Replacement: step 5, image 1 of 1
      • After removing the slide panel the back of the screen will be visible. First, remove the connector ribbon attached near the bottom of the phone. Just like disconnecting the first end of it this end is also removed by popping it off.
      Ask FixBot
    6. LG Neon GT 365 Screen Replacement: step 6, image 1 of 1
      • Carefully peel the three pieces of tape off the phone. The first two pieces of tape are green located at the bottom left and bottom right of the phone.
      Ask FixBot
    7. LG Neon GT 365 Screen Replacement: step 7, image 1 of 2 LG Neon GT 365 Screen Replacement: step 7, image 2 of 2
      • Hold the horizontal copper ribbon down with 2 fingers on each side of the tape.
      • Lastly, carefully peel off the golden piece of tape circled, without ripping or damaging the copper ribbon and across the silver LCD.
      Ask FixBot
    8. LG Neon GT 365 Screen Replacement: step 8, image 1 of 1
      • Now, disconnect the copper-colored ribbon. Pop off the ribbon and if it is still attached at the top that's ok.
      Ask FixBot
    9. LG Neon GT 365 Screen Replacement: step 9, image 1 of 1
      • Go around and under the silver LCD. Then, use the popping tool to lift the silver screen.
      Ask FixBot
    10. LG Neon GT 365 Screen Replacement: step 10, image 1 of 2 LG Neon GT 365 Screen Replacement: step 10, image 2 of 2
      • Once the silver LCD has been lifted up slightly slide the bottom half of the green circuit board off the phone by pulling down on it.
      • After the green circuit board is removed you will be able to pop the screen out. Grab a new screen and slide it in to replace it!
      • Follow the instructions in reverse to reassemble the phone with your new screen.
      Ask FixBot
To reassemble your device, follow these instructions in reverse.
kristie
538 Reputation
5 Guides authored
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 Member of UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 85
All Time: 1,480
