LG Muziq LX570 Keypad Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
30
All Time:
1,064
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will help you through the process of replacing the LG Muziq's keypad.
Tools
    1. LG Muziq LX570 Keypad Replacement, Battery: step 1, image 1 of 2 LG Muziq LX570 Keypad Replacement, Battery: step 1, image 2 of 2
      • Slide the battery cover release towards top of phone.
      • Place one finger at each side of the battery cover.
      • Lift and remove the battery cover.
      Ask FixBot
    2. LG Muziq LX570 Keypad Replacement: step 2, image 1 of 2 LG Muziq LX570 Keypad Replacement: step 2, image 2 of 2
      • Place a finger at the top corner of the battery and lift out of the phone.
      Ask FixBot
    1. LG Muziq LX570 Keypad Replacement, Rear Case: step 3, image 1 of 2 LG Muziq LX570 Keypad Replacement, Rear Case: step 3, image 2 of 2
      • Use the spudger to lift up the two screw covers at the top of the phone.
      • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
      Ask FixBot
    2. LG Muziq LX570 Keypad Replacement: step 4, image 1 of 3 LG Muziq LX570 Keypad Replacement: step 4, image 2 of 3 LG Muziq LX570 Keypad Replacement: step 4, image 3 of 3
      • Use the spudger to lift up the rear case from the phone.
      • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
      • Remove the rear case from the device.
      Ask FixBot
    1. LG Muziq LX570 Keypad Replacement, Motherboard: step 5, image 1 of 3 LG Muziq LX570 Keypad Replacement, Motherboard: step 5, image 2 of 3 LG Muziq LX570 Keypad Replacement, Motherboard: step 5, image 3 of 3
      • Use the spudger to lift the motherboard from the phone.
      Ask FixBot
    1. LG Muziq LX570 Keypad Replacement, Keypad: step 6, image 1 of 3 LG Muziq LX570 Keypad Replacement, Keypad: step 6, image 2 of 3 LG Muziq LX570 Keypad Replacement, Keypad: step 6, image 3 of 3
      • Caution: The circuit board is connected via ribbon to the phone. Do not break this connection.
      • Note: The circuit board is attached by clips on both sides of the board. Detach each clip before removing the motherboard from the phone.
      • Use the spudger to detach the circuit board from the phone.
      Ask FixBot
    2. LG Muziq LX570 Keypad Replacement: step 7, image 1 of 3 LG Muziq LX570 Keypad Replacement: step 7, image 2 of 3 LG Muziq LX570 Keypad Replacement: step 7, image 3 of 3
      • Open the phone to expose the keypad.
      • Use your finger to push the keypad from the front towards the circuit board.
      • Remove the keypad from the phone.
      Ask FixBot
Braden Burk
1 Reputation
5 Guides authored
Cal Poly, Team 3-29, Amido Winter 2012 Member of Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 30
All Time: 1,064
