Up to 20% off select tools
LG Lucid 4G SIM Card Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
79
All Time:
928
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In order to remove the SIM card, you need to remove the battery of this phone first. This guide will help you do so safely and effectively.
    1. LG Lucid 4G SIM Card Replacement, Battery: step 1, image 1 of 3 LG Lucid 4G SIM Card Replacement, Battery: step 1, image 2 of 3 LG Lucid 4G SIM Card Replacement, Battery: step 1, image 3 of 3
      • Turn off the phone by pressing the power button, then press "Power Off", then press "OK" when notified that your phone will shut down.
      Ask FixBot
    2. LG Lucid 4G SIM Card Replacement: step 2, image 1 of 2 LG Lucid 4G SIM Card Replacement: step 2, image 2 of 2
      • Flip the phone so that its back plate is facing upward.
      • Use your fingernail or prying tool to lift the back plate of the phone open by using the notch at the bottom.
      Ask FixBot
    3. LG Lucid 4G SIM Card Replacement: step 3, image 1 of 2 LG Lucid 4G SIM Card Replacement: step 3, image 2 of 2
      • Using the notch located near the bottom center, remove the battery with a prying tool or your fingernail.
      Ask FixBot
    1. LG Lucid 4G SIM Card Replacement, SIM Card: step 4, image 1 of 1
      • After you have cleaned the battery area, locate the SIM card slot.
      Ask FixBot
    2. LG Lucid 4G SIM Card Replacement: step 5, image 1 of 1
      • Using your finger, carefully remove the SIM card from its slot by moving it toward the battery area.
      Ask FixBot
Author
with
Margaret Huck
219 Reputation
2 Guides authored
Ohio State, Team 1-1, Wilder Spring 2017 Member of Ohio State, Team 1-1, Wilder Spring 2017
OSU-WILDER-S17S1G1
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 79
All Time: 928
