Up to 20% off select tools
LG Leon LTE SIM Card Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
81
All Time:
1,580
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a SIM card in your LG Leon LTE.
    1. LG Leon LTE SIM Card Replacement, SIM card: step 1, image 1 of 2 LG Leon LTE SIM Card Replacement, SIM card: step 1, image 2 of 2
      • First, make sure to turn the phone over so that you are viewing the backside. The battery is located inside the back of the phone.
      Ask FixBot
    2. LG Leon LTE SIM Card Replacement: step 2, image 1 of 3 LG Leon LTE SIM Card Replacement: step 2, image 2 of 3 LG Leon LTE SIM Card Replacement: step 2, image 3 of 3
      • Second, using your opening tool in an upward direction, carefully pry the back of the phone open at the incision area. This can be found at the bottom of the phone. You will now have access to the battery.
      • Once you have access to the battery, remove it carefully so that you can get to the SIM card. The SIM card can be seen in the third image.
      • Battery removal is not pictured.
      Ask FixBot
    3. LG Leon LTE SIM Card Replacement: step 3, image 1 of 2 LG Leon LTE SIM Card Replacement: step 3, image 2 of 2
      • Once the SIM card is accessible, slide it from the SIM holder as demonstrated. Apply a downward force in an outward motion.
      • Slight force will be needed when pulling the SIM card from the SIM card holder.
      Ask FixBot
Author
with
Geul Kim
682 Reputation
5 Guides authored
1 Guide Comment
You should do one on how to replace the SIM card tray
Wolfgang 847 - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 81
All Time: 1,580
