Up to 20% off select tools
LG LX160 Back Casing Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
18
All Time:
2,442
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
The following steps will provide support on how to remove and replace the casing of a damaged LG LX160 flip phone. Use an area that is clean and clear of debris and make sure that you have the proper tools for replacement before taking apart your device.
    1. LG LX160 Back Casing Replacement, Battery: step 1, image 1 of 1
      • Place the phone on a flat surface with the back facing upward.
      • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
      Ask FixBot
    2. LG LX160 Back Casing Replacement: step 2, image 1 of 1
      • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
      Ask FixBot
    3. LG LX160 Back Casing Replacement: step 3, image 1 of 1
      • Remove the battery completely from the phone and place the battery off to the side.
      Ask FixBot
    1. LG LX160 Back Casing Replacement, Back Casing: step 4, image 1 of 1
      • Now that the battery has been completely removed, hold the phone upright.
      • Pull off all rubber tabs covering the headphone jack and the power input port. Do this before continuing the next steps.
      Ask FixBot
    2. LG LX160 Back Casing Replacement: step 5, image 1 of 1
      • Flip the phone with the backside facing up.
      • Using the Phillips #00 Screwdriver, unscrew the 6 screws that hold the back casing together.
      Ask FixBot
    3. LG LX160 Back Casing Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Located at the top of the logic board there is a small rectangle with a white pad on it, use your tweezers and gently grip the neck of the orange wire.
      • Pull up gently on the orange wire until it comes loose. Do not be concerned with gentleness, it may require some force.
      Ask FixBot
Author
with
Shane Smith
1 Reputation
2 Guides authored
Cal Poly, Team 11-2, Forte Winter 2010 Member of Cal Poly, Team 11-2, Forte Winter 2010
CPSU-FORTE-W10S11G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 18
All Time: 2,442
