Up to 20% off select tools
LG LX150 Screen Replacement
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
82
All Time:
1,996
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to remove the LG LX150's sceen.
    1. LG LX150 Screen Replacement, Front Cover: step 1, image 1 of 3 LG LX150 Screen Replacement, Front Cover: step 1, image 2 of 3 LG LX150 Screen Replacement, Front Cover: step 1, image 3 of 3
      • Use the spudger to pry out the indicated rubber squares.
      • Use the #0 Phillips screwdriver to take out the revealed screws.
      Ask FixBot
    2. LG LX150 Screen Replacement: step 2, image 1 of 3 LG LX150 Screen Replacement: step 2, image 2 of 3 LG LX150 Screen Replacement: step 2, image 3 of 3
      • Carefully lodge the spudger between the face plate and the hinge mechanism.
      • Gently pry the face plate until it releases from place holders.
      Ask FixBot
    1. LG LX150 Screen Replacement, Screen: step 3, image 1 of 2 LG LX150 Screen Replacement, Screen: step 3, image 2 of 2
      • Apply even amounts of force upon removing screen, otherwise cracking may occur.
      • Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
      • Carefully use both thumbs and apply pressure to the back of the screen to pop out.
      Ask FixBot
Author
with
Tye Barba
88 Reputation
2 Guides authored
Cal Poly, Team 10-44, Garner Spring 2010 Member of Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 82
All Time: 1,996
