Up to 20% off select tools
LG LX150 Keypad Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
84
All Time:
1,663
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If your keypad is faulty and/or not working, you will want to replace it using this guide.
    1. LG LX150 Keypad Replacement, Back Cover: step 1, image 1 of 3 LG LX150 Keypad Replacement, Back Cover: step 1, image 2 of 3 LG LX150 Keypad Replacement, Back Cover: step 1, image 3 of 3
      • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
      • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
      • The battery will be visible after removing the back cover.
      Ask FixBot
    1. LG LX150 Keypad Replacement, Battery: step 2, image 1 of 2 LG LX150 Keypad Replacement, Battery: step 2, image 2 of 2
      • Simultaneously push the battery forward and pull up from the bottom.
      Ask FixBot
    2. LG LX150 Keypad Replacement: step 3, image 1 of 1
      • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
      • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
      Ask FixBot
    1. LG LX150 Keypad Replacement, Internal Back Cover: step 4, image 1 of 3 LG LX150 Keypad Replacement, Internal Back Cover: step 4, image 2 of 3 LG LX150 Keypad Replacement, Internal Back Cover: step 4, image 3 of 3
      • Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
      • Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
      Ask FixBot
    2. LG LX150 Keypad Replacement: step 5, image 1 of 2 LG LX150 Keypad Replacement: step 5, image 2 of 2
      • Remove the internal back cover after loosening all the corners.
      • The second picture below is what you will see after removing the internal back cover.
      Ask FixBot
    1. LG LX150 Keypad Replacement, Motherboard: step 6, image 1 of 1
      • Lift the motherboard from the bottom to loosen it.
      Ask FixBot
    2. LG LX150 Keypad Replacement: step 7, image 1 of 1
      • Remove the pin socket that connects the screen to the motherboard by pulling up away from the motherboard.
      Ask FixBot
    3. LG LX150 Keypad Replacement: step 8, image 1 of 2 LG LX150 Keypad Replacement: step 8, image 2 of 2
      • Remove the motherboard.
      • The keypad will now be visible, as shown in the second picture.
      Ask FixBot
    1. LG LX150 Keypad Replacement, Keypad: step 9, image 1 of 1
      • To remove the key pad, simply pull it off from the LG LX150 frame.
      Ask FixBot
    2. LG LX150 Keypad Replacement: step 10, image 1 of 1
      • When the key pad is removed, the frame will be all that is left.
      • If you wish to replace the key pad, place the new keypad on to the frame and reassemble the phone to resume use.
      Ask FixBot
Author
with
Andrea
110 Reputation
4 Guides authored
Cal Poly, Team 10-44, Garner Spring 2010 Member of Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 84
All Time: 1,663
