Up to 20% off select tools
LG LX150 Internal Back Cover Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
17
Past 30 Days:
83
All Time:
2,357
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will show you how to remove the plastic cover between the battery and motherboard.
    1. LG LX150 Internal Back Cover Replacement, Back Cover: step 1, image 1 of 3 LG LX150 Internal Back Cover Replacement, Back Cover: step 1, image 2 of 3 LG LX150 Internal Back Cover Replacement, Back Cover: step 1, image 3 of 3
      • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
      • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
      • The battery will be visible after removing the back cover.
      Ask FixBot
    1. LG LX150 Internal Back Cover Replacement, Battery: step 2, image 1 of 2 LG LX150 Internal Back Cover Replacement, Battery: step 2, image 2 of 2
      • Simultaneously push the battery forward and pull up from the bottom.
      Ask FixBot
    2. LG LX150 Internal Back Cover Replacement: step 3, image 1 of 1
      • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
      • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
      Ask FixBot
    1. LG LX150 Internal Back Cover Replacement, Internal Back Cover: step 4, image 1 of 3 LG LX150 Internal Back Cover Replacement, Internal Back Cover: step 4, image 2 of 3 LG LX150 Internal Back Cover Replacement, Internal Back Cover: step 4, image 3 of 3
      • Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
      • Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
      Ask FixBot
    2. LG LX150 Internal Back Cover Replacement: step 5, image 1 of 2 LG LX150 Internal Back Cover Replacement: step 5, image 2 of 2
      • Remove the internal back cover after loosening all the corners.
      • The second picture below is what you will see after removing the internal back cover.
      Ask FixBot
Author
with
Daniel Simpson
60 Reputation
2 Guides authored
Cal Poly, Team 10-44, Garner Spring 2010 Member of Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 83
All Time: 2,357
