LG L1200 Outer LCD Screen Replacement
    1. LG L1200 Outer LCD Screen Replacement, Inner LCD Screen: step 1, image 1 of 1
      • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
      • Flip open the phone and locate the four screw covers.
      Ask FixBot
    2. LG L1200 Outer LCD Screen Replacement: step 2, image 1 of 1
      • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
      Ask FixBot
    3. LG L1200 Outer LCD Screen Replacement: step 3, image 1 of 1
      • Using a T6 Torx screwdriver, remove all four screws.
      Ask FixBot
    4. LG L1200 Outer LCD Screen Replacement: step 4, image 1 of 3 LG L1200 Outer LCD Screen Replacement: step 4, image 2 of 3 LG L1200 Outer LCD Screen Replacement: step 4, image 3 of 3
      • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
      • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
      Ask FixBot
    5. LG L1200 Outer LCD Screen Replacement: step 5, image 1 of 2 LG L1200 Outer LCD Screen Replacement: step 5, image 2 of 2
      • Pull the inner screen cover towards you and up in order to separate it from the front cover.
      Ask FixBot
    6. LG L1200 Outer LCD Screen Replacement: step 6, image 1 of 1
      • Remove the tape from the bottom of the LCD screen.
      Ask FixBot
    7. LG L1200 Outer LCD Screen Replacement: step 7, image 1 of 3 LG L1200 Outer LCD Screen Replacement: step 7, image 2 of 3 LG L1200 Outer LCD Screen Replacement: step 7, image 3 of 3
      • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
      Ask FixBot
    8. LG L1200 Outer LCD Screen Replacement: step 8, image 1 of 3 LG L1200 Outer LCD Screen Replacement: step 8, image 2 of 3 LG L1200 Outer LCD Screen Replacement: step 8, image 3 of 3
      • Flip the screen over so that you can see the outer LCD screen and the circuit board.
      • Insert spudger in the bottom right corner.
      • Lift up and move the spudger across the bottom.
      • The third photo is rotated 180 degrees.
      Ask FixBot
    9. LG L1200 Outer LCD Screen Replacement: step 9, image 1 of 2 LG L1200 Outer LCD Screen Replacement: step 9, image 2 of 2
      • Use the pointy side of the spudger to peel off the interior tape.
      • Flip the assembly over and peel the circuit board from the screen.
      Ask FixBot
    10. LG L1200 Outer LCD Screen Replacement: step 10, image 1 of 2 LG L1200 Outer LCD Screen Replacement: step 10, image 2 of 2
      • Use the spudger to remove the LCD screen from its backing.
      Ask FixBot
    1. LG L1200 Outer LCD Screen Replacement, Outer LCD Screen: step 11, image 1 of 1
      • The outer LCD screen can be found on the circuit board, which is attached to the back of the inner LCD screen.
      Ask FixBot
    2. LG L1200 Outer LCD Screen Replacement: step 12, image 1 of 2 LG L1200 Outer LCD Screen Replacement: step 12, image 2 of 2
      • Use an IPod opening tool to carefully lift the screen from its backing.
      • Use your finger to pull the screen forward.
      Ask FixBot
    3. LG L1200 Outer LCD Screen Replacement: step 13, image 1 of 2 LG L1200 Outer LCD Screen Replacement: step 13, image 2 of 2
      • Pull the screen and the tape ribbon off the circuit board.
      Ask FixBot
Joshua Herrmann
8 Reputation
8 Guides authored
Cal Poly, Team 6-14, Maness Spring 2010 Member of Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 21
All Time: 1,240
