LG L1200 Logic Board Replacement
    1. LG L1200 Logic Board Replacement, Logic Board: step 1, image 1 of 1
      • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
      • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
      Ask FixBot
    2. LG L1200 Logic Board Replacement: step 2, image 1 of 1
      • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
      Ask FixBot
    3. LG L1200 Logic Board Replacement: step 3, image 1 of 1
      • Use IPod opening tool to separate back housing.
      • There are two tabs located on either side of the phone.
      Ask FixBot
    4. LG L1200 Logic Board Replacement: step 4, image 1 of 1
      • Separate the back housing from the phone.
      • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
      Ask FixBot
    5. LG L1200 Logic Board Replacement: step 5, image 1 of 1
      • Use a spudger to disconnect antenna wire.
      Ask FixBot
    6. LG L1200 Logic Board Replacement: step 6, image 1 of 1
      • Use the IPod opening tool to pop out the logic board.
      Ask FixBot
    7. LG L1200 Logic Board Replacement: step 7, image 1 of 1
      • Use the IPod opening tool to disconnect the main ribbon.
      Ask FixBot
    8. LG L1200 Logic Board Replacement: step 8, image 1 of 1
      • Once the ribbon is detached, remove the logic board and replace if necessary.
      Ask FixBot
Joshua Herrmann
8 Reputation
8 Guides authored
Cal Poly, Team 6-14, Maness Spring 2010 Member of Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 37
All Time: 1,605
