Up to 20% off select tools
LG L1200 Keypad Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
16
All Time:
1,551
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will help you replace the keypad of the phone.
    1. LG L1200 Keypad Replacement, Logic Board: step 1, image 1 of 1
      • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
      • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
      Ask FixBot
    2. LG L1200 Keypad Replacement: step 2, image 1 of 1
      • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
      Ask FixBot
    3. LG L1200 Keypad Replacement: step 3, image 1 of 1
      • Use IPod opening tool to separate back housing.
      • There are two tabs located on either side of the phone.
      Ask FixBot
    4. LG L1200 Keypad Replacement: step 4, image 1 of 1
      • Separate the back housing from the phone.
      • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
      Ask FixBot
    5. LG L1200 Keypad Replacement: step 5, image 1 of 1
      • Use a spudger to disconnect antenna wire.
      Ask FixBot
    6. LG L1200 Keypad Replacement: step 6, image 1 of 1
      • Use the IPod opening tool to pop out the logic board.
      Ask FixBot
    7. LG L1200 Keypad Replacement: step 7, image 1 of 1
      • Use the IPod opening tool to disconnect the main ribbon.
      Ask FixBot
    8. LG L1200 Keypad Replacement: step 8, image 1 of 1
      • Once the ribbon is detached, remove the logic board and replace if necessary.
      Ask FixBot
    1. LG L1200 Keypad Replacement, Keypad: step 9, image 1 of 1
      • The back of the keypad is shown here, next to the logic board (the logic board is turned over to expose the buttons).
      Ask FixBot
    2. LG L1200 Keypad Replacement: step 10, image 1 of 2 LG L1200 Keypad Replacement: step 10, image 2 of 2
      • Using a spudger, lift the keypad off of the tabs.
      Ask FixBot
Author
with
Joshua Herrmann
8 Reputation
8 Guides authored
Cal Poly, Team 6-14, Maness Spring 2010 Member of Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 1,551
