Up to 20% off select tools
LG KP100 Keypad Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
19
All Time:
1,887
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your keypad stops functioning or the keys are sticking, you may need to go inside the phone to replace the rubber keypad. This guide will show you just how to do that.
    1. LG KP100 Keypad Replacement, Battery: step 1, image 1 of 2 LG KP100 Keypad Replacement, Battery: step 1, image 2 of 2
      • Begin by taking the back battery cover off.
      • Put your index finger on the white notch and apply pressure.
      • While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
      Ask FixBot
    2. LG KP100 Keypad Replacement: step 2, image 1 of 2 LG KP100 Keypad Replacement: step 2, image 2 of 2
      • Remove the battery.
      • Put your index finger in the notch above the battery near the top of the casing.
      • While applying pressure against the battery, lift up and take out the battery.
      Ask FixBot
    1. LG KP100 Keypad Replacement, SIM Card: step 3, image 1 of 3 LG KP100 Keypad Replacement, SIM Card: step 3, image 2 of 3 LG KP100 Keypad Replacement, SIM Card: step 3, image 3 of 3
      • Remove the SIM card from its housing.
      • Put your finger in the provided notch below the SIM card and begin to push the SIM card towards the top of the device.
      • After it is out of the metal housing, it is free to be removed.
      Ask FixBot
    1. LG KP100 Keypad Replacement, Motherboard: step 4, image 1 of 1
      • Remove the four screws along the edge of the phone body, as shown in the picture to the left.
      Ask FixBot
    2. LG KP100 Keypad Replacement: step 5, image 1 of 2 LG KP100 Keypad Replacement: step 5, image 2 of 2
      • Using the plastic opening tool, pry open the body of the phone, starting at the bottom of the phone (this tends to be the easiest place to start).
      • Double check to make sure the SIM card is removed from its housing. You will not be able to pry open the body of the phone if the SIM card remains in its housing.
      • Continue by sliding the opening tool around the perimeter of the phone. You should hear multiple clicking sounds as you complete this, indicating the clips are becoming unlatched.
      • This may take a few tries to get correct. Don't give up if it doesn't work the very first time.
      Ask FixBot
    3. LG KP100 Keypad Replacement: step 6, image 1 of 3 LG KP100 Keypad Replacement: step 6, image 2 of 3 LG KP100 Keypad Replacement: step 6, image 3 of 3
      • Put the red casing aside and remove the motherboard from the front casing of the phone by carefully dislodging it from its two clips near the top of the phone.
      Ask FixBot
    1. LG KP100 Keypad Replacement, Keypad: step 7, image 1 of 2 LG KP100 Keypad Replacement, Keypad: step 7, image 2 of 2
      • As you can see, the rubber keypad is attached to the front casing. Gently remove it from the case by pinching any part of it and lifting. Don't worry, it isn't attached too firmly and is easily removable.
      Ask FixBot
Author
with
Preston Brown
28 Reputation
5 Guides authored
Cal Poly, Team 6-20, Amido Spring 2012 Member of Cal Poly, Team 6-20, Amido Spring 2012
CPSU-AMIDO-S12S6G20
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 19
All Time: 1,887
