LG K7 Volume & On/Off Buttons Replacement
    1. LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: step 1, image 1 of 2 LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: step 1, image 2 of 2
      • Remove the back cover using a plastic opening tool.
      • Remove the battery using a plastic opening tool.
      Ask FixBot
    2. LG K7 Volume & On/Off Buttons Replacement: step 2, image 1 of 1
      • Remove the nine 4mm Phillips #000 screws.
      • The cover should lift off easily once the screws are out.
      • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
      Ask FixBot
    3. LG K7 Volume & On/Off Buttons Replacement: step 3, image 1 of 1
      • Pry off the silver button housing using the plastic opening tool.
      Ask FixBot
    4. LG K7 Volume & On/Off Buttons Replacement: step 4, image 1 of 1
      • Separate the screen from the rest of the phone using the plastic opening tool.
      • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
      • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
      Ask FixBot
    5. LG K7 Volume & On/Off Buttons Replacement: step 5, image 1 of 3 LG K7 Volume & On/Off Buttons Replacement: step 5, image 2 of 3 LG K7 Volume & On/Off Buttons Replacement: step 5, image 3 of 3
      • Peel off the orange cable using a plastic opening tool.
      Ask FixBot
    6. LG K7 Volume & On/Off Buttons Replacement: step 6, image 1 of 1
      • Remove the volume/power button cable from the rest of the phone using the plastic opening tool to break the adhesive.
      Ask FixBot
Jack Lepkowski
136 Reputation
1 Guide authored
IUPUI, Team S3-G2, Harley Fall 2019 Member of IUPUI, Team S3-G2, Harley Fall 2019
IUPUI-HARLEY-F19S3G2
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 68
All Time: 933
