LG K7 T-Mobile Rear Phone Camera Replacement
    1. LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: step 1, image 1 of 2 LG K7 T-Mobile Rear Phone  Camera Replacement, Battery: step 1, image 2 of 2
      • Flip the LG K7 over so that the back of the phone is facing up.
      • Locate the small notch on the bottom left side of the phone.
      Ask FixBot
    2. LG K7 T-Mobile Rear Phone  Camera Replacement: step 2, image 1 of 1
      • Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
      Ask FixBot
    3. LG K7 T-Mobile Rear Phone  Camera Replacement: step 3, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: step 4, image 1 of 2 LG K7 T-Mobile Rear Phone  Camera Replacement, Rear Phone  Camera: step 4, image 2 of 2
      • Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
      • Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
      Ask FixBot
    2. LG K7 T-Mobile Rear Phone  Camera Replacement: step 5, image 1 of 3 LG K7 T-Mobile Rear Phone  Camera Replacement: step 5, image 2 of 3 LG K7 T-Mobile Rear Phone  Camera Replacement: step 5, image 3 of 3
      • Turn the phone over so the screen is facing up
      • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
      • Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
      Ask FixBot
    3. LG K7 T-Mobile Rear Phone  Camera Replacement: step 6, image 1 of 3 LG K7 T-Mobile Rear Phone  Camera Replacement: step 6, image 2 of 3 LG K7 T-Mobile Rear Phone  Camera Replacement: step 6, image 3 of 3
      • Locate the ribbon cable that holds the camera's ribbon cable in place.
      • Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
      • Holding the camera ribbon you just released pull upwards and the camera should release from the case.
      Ask FixBot
Salem Jean
216 Reputation
1 Guide authored
USF Tampa, Team S2-G5, Nance Fall 2017 Member of USF Tampa, Team S2-G5, Nance Fall 2017
USFT-NANCE-F17S2G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 99
All Time: 965
