LG K7 Headphone Jack Replacement
    1. LG K7 Headphone Jack Replacement, Battery: step 1, image 1 of 2 LG K7 Headphone Jack Replacement, Battery: step 1, image 2 of 2
      • Place a fingernail in slot at in the bottom edge of the phone.
      • Pull up on the back panel while holding down the rest of the phone steady with your hand.
      • Do not to pull too hard on the back panel or you may break it.
      Ask FixBot
    2. LG K7 Headphone Jack Replacement: step 2, image 1 of 2 LG K7 Headphone Jack Replacement: step 2, image 2 of 2
      • Place a fingernail in the slot at the bottom edge of the battery.
      • Pull the battery out.
      Ask FixBot
    1. LG K7 Headphone Jack Replacement, Headphone Jack: step 3, image 1 of 3 LG K7 Headphone Jack Replacement, Headphone Jack: step 3, image 2 of 3 LG K7 Headphone Jack Replacement, Headphone Jack: step 3, image 3 of 3
      • Remove the nine frame screws with a #J00 screwdriver.
      • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
      • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
      • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
      Ask FixBot
    2. LG K7 Headphone Jack Replacement: step 4, image 1 of 2 LG K7 Headphone Jack Replacement: step 4, image 2 of 2
      • Use a plastic opening tool to separate the screen from the outer frame.
      • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
      • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
      Ask FixBot
    3. LG K7 Headphone Jack Replacement: step 5, image 1 of 1
      • Line up a plastic opening tool underneath the headphone jack and hold the main body of the phone down.
      • Lift or the plastic opening tool to separate the headphone jack from the main body of the phone.
      • Be careful to not damage the components that the headphone jack sits in.
      Ask FixBot
2 other people completed this guide.
James Ngo
461 Reputation
4 Guides authored
Cal Poly, Team S21-G5, Banghart Winter 2018 Member of Cal Poly, Team S21-G5, Banghart Winter 2018
CPSU-BANGHART-W18S21G5
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 69
All Time: 1,334
