LG K7 Charging Port Replacement
    1. LG K7 Charging Port Replacement, Charging Port: step 1, image 1 of 2 LG K7 Charging Port Replacement, Charging Port: step 1, image 2 of 2
      • Remove the back cover by using the plastic opening tool.
      • Remove battery by using the plastic opening tool.
      Ask FixBot
    2. LG K7 Charging Port Replacement: step 2, image 1 of 1
      • Remove the nine 4mm Phillips #000 screws.
      • The cover should lift off easily once the screws are out.
      • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
      Ask FixBot
    3. LG K7 Charging Port Replacement: step 3, image 1 of 1
      • Place the plastic opening tool between the screen and the plastic edge of the phone and pry carefully until screen pops off.
      • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
      • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
      Ask FixBot
    4. LG K7 Charging Port Replacement: step 4, image 1 of 1
      • Place the plastic opening tool between the blue motherboard and black plate and pry until the motherboard pops off.
      Ask FixBot
    5. LG K7 Charging Port Replacement: step 5, image 1 of 2 LG K7 Charging Port Replacement: step 5, image 2 of 2
      • Heat up the four connection points using a soldering iron.
      • Once hot, gently push the port off.
      • Soldering iron is hot! Use with caution.
      • Be careful not to touch other components with the soldering iron.
      Ask FixBot
Stephen Damm
167 Reputation
1 Guide authored
IUPUI, Team S3-G2, Harley Fall 2019 Member of IUPUI, Team S3-G2, Harley Fall 2019
IUPUI-HARLEY-F19S3G2
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 69
All Time: 977
