Up to 20% off select tools
LG K40S Back Panel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
58
All Time:
636
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the back panel on your LG K40S. If you damage the fingerprint scanner or the flex cable for it during your repair, follow this guide to replace that too.
    1. LG K40S Back Panel Replacement, Precautions: step 1, image 1 of 3 LG K40S Back Panel Replacement, Precautions: step 1, image 2 of 3 LG K40S Back Panel Replacement, Precautions: step 1, image 3 of 3
      • Power off your phone by holding the power key, pressing power off, then confirm.
      • Make sure that the battery of your phone is below 25% before opening to avoid battery fires should an accident happen.
      Ask FixBot
    2. LG K40S Back Panel Replacement, Removing SIM & SD Card trays: step 2, image 1 of 3 LG K40S Back Panel Replacement, Removing SIM & SD Card trays: step 2, image 2 of 3 LG K40S Back Panel Replacement, Removing SIM & SD Card trays: step 2, image 3 of 3
      • Use a SIM Eject tool (real one, bent paperclip or otherwise) to eject the 2 SIM & SD Card trays before removing them from the phone.
      Ask FixBot
    3. LG K40S Back Panel Replacement, Removing back panel: step 3, image 1 of 3 LG K40S Back Panel Replacement, Removing back panel: step 3, image 2 of 3 LG K40S Back Panel Replacement, Removing back panel: step 3, image 3 of 3
      • The back panel is made of plastic significantly reducing the chance of breakage compared to a glass back.
      • The back panel is held on with plastic clips and can be unclipped using plastic picks.
      • Be careful around the buttons so as to not damage the flex cables they reside on. The buttons on the back panel are seperate from the flex cable containing the buttons
      • Do not fully pull the back panel off straight away, you may rip the flex cable for the fingerprint scanner.
      Ask FixBot
    4. LG K40S Back Panel Replacement, Disconnecting fingerprint scanner: step 4, image 1 of 3 LG K40S Back Panel Replacement, Disconnecting fingerprint scanner: step 4, image 2 of 3 LG K40S Back Panel Replacement, Disconnecting fingerprint scanner: step 4, image 3 of 3
      • Open the back panel to the right as shown in image 1.
      • Disconnect the fingerprint scanner flex cable using a plastic pick or spudger
      • Pull the old back panel away from the phone.
      Ask FixBot
    5. LG K40S Back Panel Replacement, Removing fingerprint scanner from old back panel: step 5, image 1 of 3 LG K40S Back Panel Replacement, Removing fingerprint scanner from old back panel: step 5, image 2 of 3 LG K40S Back Panel Replacement, Removing fingerprint scanner from old back panel: step 5, image 3 of 3
      • This step can be skipped if you are also replacing the fingerprint scanner
      • Carefully remove the black tape covering the fingerprint scanner using your fingers or a plastic pick, being careful not to insert your pick too far if using one.
      • Carefully push the fingerprint scanner through the old back panel.
      • Use a plastic pick to carefully unadhere the flex cable from the old back panel.
      • Pull the fingerprint sensor away from the old back panel.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order making sure to reinstall the fingerprint scanner onto the new back panel.
Author
with
JoshAtticus
351 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 58
All Time: 636
