LG K30 Front-Facing Camera Replacement
    1. LG K30 Front-Facing Camera Replacement, Battery: step 1, image 1 of 2 LG K30 Front-Facing Camera Replacement, Battery: step 1, image 2 of 2
      • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your Phone before beginning disassembly.
      • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
      Ask FixBot
    2. LG K30 Front-Facing Camera Replacement: step 2, image 1 of 1
      • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
      Ask FixBot
    3. LG K30 Front-Facing Camera Replacement: step 3, image 1 of 1
      • Use a metal spudger or plastic opening tool to pry open the outer cover.
      Ask FixBot
    4. LG K30 Front-Facing Camera Replacement: step 4, image 1 of 1
      • Use the flat end of a spudger to detach the battery connector from the logic board.
      Ask FixBot
    5. LG K30 Front-Facing Camera Replacement: step 5, image 1 of 2 LG K30 Front-Facing Camera Replacement: step 5, image 2 of 2
      • Use a spudger to pry the battery from the phone.
      • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
      • Do not bend or puncture the battery.
      Ask FixBot
    1. LG K30 Front-Facing Camera Replacement, Front-Facing Camera: step 6, image 1 of 1
      • Use the plastic spudger to disconnect the cable connector.
      Ask FixBot
    2. LG K30 Front-Facing Camera Replacement: step 7, image 1 of 1
      • Gently pry out the front-facing camera from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 61
All Time: 628
