LG K30 Battery Replacement
    1. LG K30 Battery Replacement, Battery: step 1, image 1 of 2 LG K30 Battery Replacement, Battery: step 1, image 2 of 2
      • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your Phone before beginning disassembly.
      • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
      Ask FixBot
    2. LG K30 Battery Replacement: step 2, image 1 of 1
      • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
      Ask FixBot
    3. LG K30 Battery Replacement: step 3, image 1 of 1
      • Use a metal spudger or plastic opening tool to pry open the outer cover.
      Ask FixBot
    4. LG K30 Battery Replacement: step 4, image 1 of 1
      • Use the flat end of a spudger to detach the battery connector from the logic board.
      Ask FixBot
    5. LG K30 Battery Replacement: step 5, image 1 of 2 LG K30 Battery Replacement: step 5, image 2 of 2
      • Use a spudger to pry the battery from the phone.
      • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
      • Do not bend or puncture the battery.
      Ask FixBot
12 other people completed this guide.
2 Guide Comments
There's no description of removing the display or supporting it. Why is an LG K30 screen with frame required?
P Schmied - Reply Share
thank you it really meant a lot
Albert E - Reply Share
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 74
All Time: 14,408
