LG K20 PLUS Rear-Facing Camera Replacement
    1. LG K20 PLUS Rear-Facing Camera Replacement, Remove the back cover and battery: step 1, image 1 of 2 LG K20 PLUS Rear-Facing Camera Replacement, Remove the back cover and battery: step 1, image 2 of 2
      • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
      • Lift battery up here
      Ask FixBot
    1. LG K20 PLUS Rear-Facing Camera Replacement, Midframe: step 2, image 1 of 1
      • Remove 11 Philips screws.
      Ask FixBot
    2. LG K20 PLUS Rear-Facing Camera Replacement: step 3, image 1 of 2 LG K20 PLUS Rear-Facing Camera Replacement: step 3, image 2 of 2
      • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
      • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
      • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
      Ask FixBot
    1. LG K20 PLUS Rear-Facing Camera Replacement, Rear-Facing Camera: step 4, image 1 of 1
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
      Ask FixBot
Patrick
6,782 Reputation
21 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 56
All Time: 729
