LG K20 PLUS Front Camera Replacement
    1. LG K20 PLUS Front Camera Replacement, Remove the back cover and battery: step 1, image 1 of 2 LG K20 PLUS Front Camera Replacement, Remove the back cover and battery: step 1, image 2 of 2
      • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
      • Lift battery up here
      Ask FixBot
    1. LG K20 PLUS Front Camera Replacement, Midframe: step 2, image 1 of 1
      • Remove 11 Philips screws.
      Ask FixBot
    2. LG K20 PLUS Front Camera Replacement: step 3, image 1 of 2 LG K20 PLUS Front Camera Replacement: step 3, image 2 of 2
      • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
      • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
      • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
      Ask FixBot
    1. LG K20 PLUS Front Camera Replacement, Front Camera: step 4, image 1 of 1
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Use an opening pick or a Halberd spudger to disconnect the front camera flex from its socket on the motherboard.
      • The front camera is held in by adhesive. Carefully pry between the camera and its bracket on the frame of the phone to remove it.
      • If you're having difficulty removing the front-facing camera, remove the motherboard to make more room.
      Ask FixBot
Patrick
6,791 Reputation
21 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 60
All Time: 1,032
