Up to 20% off select tools
LG Intuition Volume Buttons Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
57
All Time:
612
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 9 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the phone's volume will not increase/decrease or the buttons are not functioning properly, use this guide to replace your volume buttons.
    1. LG Intuition Volume Buttons Replacement, Battery: step 1, image 1 of 1
      • Turn the device so the two bottom screws are shown.
      Ask FixBot
    2. LG Intuition Volume Buttons Replacement: step 2, image 1 of 1
      • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
      Ask FixBot
    3. LG Intuition Volume Buttons Replacement: step 3, image 1 of 1
      • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
      Ask FixBot
    4. LG Intuition Volume Buttons Replacement: step 4, image 1 of 1
      • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
      Ask FixBot
    5. LG Intuition Volume Buttons Replacement: step 5, image 1 of 1
      • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
      Ask FixBot
    6. LG Intuition Volume Buttons Replacement: step 6, image 1 of 2 LG Intuition Volume Buttons Replacement: step 6, image 2 of 2
      • Gently raise the battery from its compartment.
      Ask FixBot
    1. LG Intuition Volume Buttons Replacement, Plastic Motherboard Shield: step 7, image 1 of 1
      • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
      Ask FixBot
    2. LG Intuition Volume Buttons Replacement: step 8, image 1 of 1
      • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
      Ask FixBot
    1. LG Intuition Volume Buttons Replacement, Volume Buttons: step 9, image 1 of 2 LG Intuition Volume Buttons Replacement, Volume Buttons: step 9, image 2 of 2
      • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
      Ask FixBot
Author
with
Thomas Morrissey
616 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 57
All Time: 612
