Up to 20% off select tools
LG Intuition Screen Protector Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
8
Past 30 Days:
67
All Time:
703
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
If your screen protector is cracked or prevents touch commands to the display, use this guide to replace your screen protector.
    1. LG Intuition Screen Protector Replacement, Battery: step 1, image 1 of 1
      • Turn the device so the two bottom screws are shown.
      Ask FixBot
    2. LG Intuition Screen Protector Replacement: step 2, image 1 of 1
      • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
      Ask FixBot
    3. LG Intuition Screen Protector Replacement: step 3, image 1 of 1
      • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
      Ask FixBot
    4. LG Intuition Screen Protector Replacement: step 4, image 1 of 1
      • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
      Ask FixBot
    5. LG Intuition Screen Protector Replacement: step 5, image 1 of 1
      • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
      Ask FixBot
    6. LG Intuition Screen Protector Replacement: step 6, image 1 of 2 LG Intuition Screen Protector Replacement: step 6, image 2 of 2
      • Gently raise the battery from its compartment.
      Ask FixBot
    1. LG Intuition Screen Protector Replacement, Plastic Motherboard Shield: step 7, image 1 of 1
      • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
      Ask FixBot
    2. LG Intuition Screen Protector Replacement: step 8, image 1 of 1
      • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
      Ask FixBot
    1. LG Intuition Screen Protector Replacement, Camera: step 9, image 1 of 1
      • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
      Ask FixBot
    2. LG Intuition Screen Protector Replacement: step 10, image 1 of 1
      • Using the ribbon beneath the camera lift it upwards and pull the camera out.
      Ask FixBot
    1. LG Intuition Screen Protector Replacement, Volume Buttons: step 11, image 1 of 2 LG Intuition Screen Protector Replacement, Volume Buttons: step 11, image 2 of 2
      • Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
      Ask FixBot
    1. LG Intuition Screen Protector Replacement, Screen Protector: step 12, image 1 of 2 LG Intuition Screen Protector Replacement, Screen Protector: step 12, image 2 of 2
      • Carefully use the plastic opening tool to pry the ribbon cable below the volume buttons on the left side of the phone.
      • Carefully use the plastic opening tool to pry the ribbon cable to the left of the camera.
      Ask FixBot
    2. LG Intuition Screen Protector Replacement: step 13, image 1 of 2 LG Intuition Screen Protector Replacement: step 13, image 2 of 2
      • Carefully use the plastic opening tool to pry the wire that connects to the bottom home and back display buttons.
      • Carefully use the plastic opening tool to pry the second wire on the right side of the battery that also connects to the bottom home and back display buttons.
      Ask FixBot
    3. LG Intuition Screen Protector Replacement: step 14, image 1 of 1
      • Carefully use the plastic opening tool to pry the motherboard from the front screen.
      Ask FixBot
    4. LG Intuition Screen Protector Replacement: step 15, image 1 of 2 LG Intuition Screen Protector Replacement: step 15, image 2 of 2
      • Remove the 5mm Phillips #00 screw below the volume buttons holding the plastic shield onto the screen display.
      • Remove the 5mm Phillips #00 screw on the top right of the phone.
      Ask FixBot
    5. LG Intuition Screen Protector Replacement: step 16, image 1 of 1
      • Carefully pull the ribbon cable upward and away from the front screen display.
      Ask FixBot
    6. LG Intuition Screen Protector Replacement: step 17, image 1 of 1
      • Carefully use the plastic opening tool to pry the screen protector from the display and motherboard.
      Ask FixBot
    7. LG Intuition Screen Protector Replacement: step 18, image 1 of 2 LG Intuition Screen Protector Replacement: step 18, image 2 of 2
      • Slowly separate the front screen from the screen protector. This will remove the screen protector from the phone.
      Ask FixBot
Author
with
Thomas Morrissey
616 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 67
All Time: 703
