Tools
Introduction
Go to step 1 ↓If your power button is not responding to pressing or is not turning on the device, use this guide to replace your power button.
Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
Carefully use the plastic opening tool to pry the ribbon cable below the volume buttons on the left side of the phone.
Carefully use the plastic opening tool to pry the ribbon cable to the left of the camera.
Slowly separate the power button from the screen display. This will release the power button.
