Up to 20% off select tools
LG Intuition Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
63
All Time:
801
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your battery fails or is not holding its charge, use this guide to replace your battery.
    1. LG Intuition Battery Replacement, Battery: step 1, image 1 of 1
      • Turn the device so the two bottom screws are shown.
      Ask FixBot
    2. LG Intuition Battery Replacement: step 2, image 1 of 1
      • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
      Ask FixBot
    3. LG Intuition Battery Replacement: step 3, image 1 of 1
      • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
      Ask FixBot
    4. LG Intuition Battery Replacement: step 4, image 1 of 1
      • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
      Ask FixBot
    5. LG Intuition Battery Replacement: step 5, image 1 of 1
      • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
      Ask FixBot
    6. LG Intuition Battery Replacement: step 6, image 1 of 2 LG Intuition Battery Replacement: step 6, image 2 of 2
      • Gently raise the battery from its compartment.
      Ask FixBot
Author
with
Thomas Morrissey
616 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 63
All Time: 801
