Up to 20% off select tools
LG Incite Touch Screen Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
96
All Time:
1,898
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 25 minutes
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
If your phone's touch screen breaks or malfunctions, this guide will show you how to easily remove and replace it.
    1. LG Incite Touch Screen Replacement, Battery: step 1, image 1 of 1
      • Hold the phone camera-side up and locate the rear cover.
      Ask FixBot
    2. LG Incite Touch Screen Replacement: step 2, image 1 of 1
      • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
      Ask FixBot
    3. LG Incite Touch Screen Replacement: step 3, image 1 of 1
      • Place the plastic opening tool in the small slot below and to the left of the battery.
      • Pry the battery upward to remove it.
      Ask FixBot
    1. LG Incite Touch Screen Replacement, Back Panel: step 4, image 1 of 1
      • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
      Ask FixBot
    2. LG Incite Touch Screen Replacement: step 5, image 1 of 1
      • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
      • Gently move the tool around the perimeter of the screen to separate it from the body.
      • You should not completely separate the screen from the device in this step.
      Ask FixBot
    3. LG Incite Touch Screen Replacement: step 6, image 1 of 1
      • Flip the device over so the battery compartment faces up.
      • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
      • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
      • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
      Ask FixBot
    1. LG Incite Touch Screen Replacement, Motherboard: step 7, image 1 of 3 LG Incite Touch Screen Replacement, Motherboard: step 7, image 2 of 3 LG Incite Touch Screen Replacement, Motherboard: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use the metal tweezers to gently peel the yellow tab from the left edge of the phone at the two plastic bases.
      • Do not completely remove the tab from the body, it should still be connected to the phone by the orange plastic.
      • Repeat this for the white tab on the opposite side of the phone.
      • This tab also has two plastic bases adhering it to the edge of the phone.
      Ask FixBot
    2. LG Incite Touch Screen Replacement: step 8, image 1 of 1
      • Insert your plastic opening tool underneath the speaker/camera panel, and gently pry it upwards.
      • Do not fully remove the panel! It should still be attached to the motherboard by a red and black wire.
      Ask FixBot
    3. LG Incite Touch Screen Replacement: step 9, image 1 of 2 LG Incite Touch Screen Replacement: step 9, image 2 of 2
      • Use the metal tweezers to gently lift the edge of the maroon tab, it should pop up easily.
      • Do not remove the tab completely, it should still be connected to the phone.
      Ask FixBot
    4. LG Incite Touch Screen Replacement: step 10, image 1 of 1
      • Insert the plastic opening tool underneath the motherboard towards the bottom edge of the phone and gently pry it from its case.
      • Lift the motherboard and slide it towards you by hand to free it from the phone.
      • The call and end buttons may fall out when the motherboard is removed! Don't lose the buttons.
      Ask FixBot
    1. LG Incite Touch Screen Replacement, Touch Screen: step 11, image 1 of 1
      Buy
      • Remove the call and end buttons using the metal tweezers.
      Ask FixBot
    2. LG Incite Touch Screen Replacement: step 12, image 1 of 1
      • Wedge the plastic opening tool between the screen and sides of the phone.
      • Slide the tool along the edge to loosen the screen.
      • Repeat for the opposite side.
      • Don't completely remove the screen yet to avoid damaging the screen.
      Ask FixBot
    3. LG Incite Touch Screen Replacement: step 13, image 1 of 1
      • Wedge the plastic opening tool under the screen where the buttons were to loosen it.
      Ask FixBot
    4. LG Incite Touch Screen Replacement: step 14, image 1 of 2 LG Incite Touch Screen Replacement: step 14, image 2 of 2
      • Gently peel the touch screen off from the bottom of the phone.
      • Do not damage the yellow tab in the upper right corner of the phone.
      Ask FixBot
5 other people completed this guide.
Author
with
Kimberly Kha
163 Reputation
5 Guides authored
Cal Poly, Team 2-18, Maness Spring 2013 Member of Cal Poly, Team 2-18, Maness Spring 2013
CPSU-MANESS-S13S2G18
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 96
All Time: 1,898
