LG Incite CT810 Motherboard Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. LG Incite CT810 Motherboard Replacement, Motherboard: step 1, image 1 of 3 LG Incite CT810 Motherboard Replacement, Motherboard: step 1, image 2 of 3 LG Incite CT810 Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Remove the four Phillips screws.
      Ask FixBot
    2. LG Incite CT810 Motherboard Replacement: step 2, image 1 of 2 LG Incite CT810 Motherboard Replacement: step 2, image 2 of 2
      • With the screws set aside, wedge your plastic opening tool in between the screen and the case surrounding it. Gently move the tool along the edge to loosen the screen from the casing. Do this again on the other side as well. The screen and case won't be completely separate in this step.
      Ask FixBot
    3. LG Incite CT810 Motherboard Replacement: step 3, image 1 of 3 LG Incite CT810 Motherboard Replacement: step 3, image 2 of 3 LG Incite CT810 Motherboard Replacement: step 3, image 3 of 3
      • Flip your phone over to the battery side. Locate the seam near the bottom of the phone between the plastic case and the metallic case. Like the previous step, wedge the opening tool into the seem, and slide it across. Then, pry the two pieces apart. Your phone should now be in two pieces.
      Ask FixBot
    4. LG Incite CT810 Motherboard Replacement: step 4, image 1 of 1
      • Here is a top-down view of what your phone should look like. There are three yellow tabs that need to be loosened in order to remove the motherboard. The third tab is located underneath the speak/camera board in red.
      Ask FixBot
    5. LG Incite CT810 Motherboard Replacement: step 5, image 1 of 3 LG Incite CT810 Motherboard Replacement: step 5, image 2 of 3 LG Incite CT810 Motherboard Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • The first two tabs are the easiest to remove. Take your metal tweezers and gently separate the white panel from the gray surface they are attached to. Do the same thing to the white panel on the other side of the phone (as shown in image 3).
      Ask FixBot
    6. LG Incite CT810 Motherboard Replacement: step 6, image 1 of 3 LG Incite CT810 Motherboard Replacement: step 6, image 2 of 3 LG Incite CT810 Motherboard Replacement: step 6, image 3 of 3
      • To get access to the third tab, insert your plastic opening tool underneath the speak/camera panel, and gently pry at it. Do not fully remove the board though! It should still be attached to the motherboard by a red and black wire. Images two and three show the tab is red.
      Ask FixBot
    7. LG Incite CT810 Motherboard Replacement: step 7, image 1 of 2 LG Incite CT810 Motherboard Replacement: step 7, image 2 of 2
      • To loosen this tab, use your metal tweezers to lift the side of the tab shown in image 1. You only need to gently lift it, it should pop off quite easily.
      Ask FixBot
    8. LG Incite CT810 Motherboard Replacement: step 8, image 1 of 3 LG Incite CT810 Motherboard Replacement: step 8, image 2 of 3 LG Incite CT810 Motherboard Replacement: step 8, image 3 of 3
      • With all three tabs removed, its time to separate the motherboard from the other casing! Insert the plastic opening tool as shown, and gently pry the motherboard from its case. Make sure to do this on all sides before fully prying the two apart. The third image shows the motherboard on the left, and the second casing on the right.
      Ask FixBot
Matthew
124 Reputation
1 Guide authored
Cal Poly, Team 2-18, Maness Spring 2013 Member of Cal Poly, Team 2-18, Maness Spring 2013
CPSU-MANESS-S13S2G18
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 11
All Time: 322
