LG GW910 Motherboard Replacement
    1. LG GW910 Motherboard Replacement, Motherboard: step 1, image 1 of 2 LG GW910 Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Remove the back cover by firmly pressing the triangle and push upwards.
      • Lift the bottom section to remove the cover.
      Ask FixBot
    2. LG GW910 Motherboard Replacement: step 2, image 1 of 2 LG GW910 Motherboard Replacement: step 2, image 2 of 2
      • Remove the battery by lifting from the bottom.
      Ask FixBot
    3. LG GW910 Motherboard Replacement: step 3, image 1 of 1
      • Remove six 3mm PH000 screws.
      Ask FixBot
    4. LG GW910 Motherboard Replacement: step 4, image 1 of 3 LG GW910 Motherboard Replacement: step 4, image 2 of 3 LG GW910 Motherboard Replacement: step 4, image 3 of 3
      • Peel off the sticker with the metal spudger.
      • Remove one 1mm PH000 screw.
      Ask FixBot
    5. LG GW910 Motherboard Replacement: step 5, image 1 of 1
      • Pry open all four sides of the back-frame gently, using the metal spudger.
      • The back-frame should come out easily.
      • Volume button and shutter button may fall out during the process.
      Ask FixBot
    6. LG GW910 Motherboard Replacement: step 6, image 1 of 1
      • Pry off the connector using the iFixit opening tool to remove the communication board.
      Ask FixBot
    7. LG GW910 Motherboard Replacement: step 7, image 1 of 3 LG GW910 Motherboard Replacement: step 7, image 2 of 3 LG GW910 Motherboard Replacement: step 7, image 3 of 3
      • Pry off the connectors using the iFixit opening tool.
      • Disconnect the antenna using the iFixit opening tool.
      • The motherboard should be able to be removed easily.
      Ask FixBot
Jonas Ke
492 Reputation
3 Guides authored
IUPUI, Team S1-G6, Hovde Fall 2018 Member of IUPUI, Team S1-G6, Hovde Fall 2018
IUPUI-HOVDE-F18S1G6
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 389
