Up to 20% off select tools
LG GW910 Keyboard Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
10
Past 30 Days:
60
All Time:
584
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will assist you while you take your phone apart. This disassembly is not a very difficult task. There will be a few connectors that will be disconnected during the process. Make sure to be cautious with them so they do not rip. There are many little screws that will be taken off the phone. Make sure that you have a clean and organized work space.
    1. LG GW910 Keyboard Replacement, Motherboard: step 1, image 1 of 2 LG GW910 Keyboard Replacement, Motherboard: step 1, image 2 of 2
      • Remove the back cover by firmly pressing the triangle and push upwards.
      • Lift the bottom section to remove the cover.
      Ask FixBot
    2. LG GW910 Keyboard Replacement: step 2, image 1 of 2 LG GW910 Keyboard Replacement: step 2, image 2 of 2
      • Remove the battery by lifting from the bottom.
      Ask FixBot
    3. LG GW910 Keyboard Replacement: step 3, image 1 of 1
      • Remove six 3mm PH000 screws.
      Ask FixBot
    4. LG GW910 Keyboard Replacement: step 4, image 1 of 3 LG GW910 Keyboard Replacement: step 4, image 2 of 3 LG GW910 Keyboard Replacement: step 4, image 3 of 3
      • Peel off the sticker with the metal spudger.
      • Remove one 1mm PH000 screw.
      Ask FixBot
    5. LG GW910 Keyboard Replacement: step 5, image 1 of 1
      • Pry open all four sides of the back-frame gently, using the metal spudger.
      • The back-frame should come out easily.
      • Volume button and shutter button may fall out during the process.
      Ask FixBot
    6. LG GW910 Keyboard Replacement: step 6, image 1 of 1
      • Pry off the connector using the iFixit opening tool to remove the communication board.
      Ask FixBot
    7. LG GW910 Keyboard Replacement: step 7, image 1 of 3 LG GW910 Keyboard Replacement: step 7, image 2 of 3 LG GW910 Keyboard Replacement: step 7, image 3 of 3
      • Pry off the connectors using the iFixit opening tool.
      • Disconnect the antenna using the iFixit opening tool.
      • The motherboard should be able to be removed easily.
      Ask FixBot
    1. LG GW910 Keyboard Replacement, Keyboard: step 8, image 1 of 1
      • Remove six 1mm PH00 screws.
      Ask FixBot
    2. LG GW910 Keyboard Replacement: step 9, image 1 of 2 LG GW910 Keyboard Replacement: step 9, image 2 of 2
      • Peel off the tape to expose the hidden screw.
      • Replacement tape might be needed.
      Ask FixBot
    3. LG GW910 Keyboard Replacement: step 10, image 1 of 2 LG GW910 Keyboard Replacement: step 10, image 2 of 2
      • Pry off the board from the side using the metal spudger tool.
      • Disconnect the antenna.
      Ask FixBot
    4. LG GW910 Keyboard Replacement: step 11, image 1 of 1
      • Remove the keyboard assembly from the main frame.
      • The keyboard cover is loose.
      • Make sure to pull the small keyboard battery out with the whole assembly
      Ask FixBot
Author
with
Jonas Ke
492 Reputation
3 Guides authored
IUPUI, Team S1-G6, Hovde Fall 2018 Member of IUPUI, Team S1-G6, Hovde Fall 2018
IUPUI-HOVDE-F18S1G6
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 60
All Time: 584
