Up to 20% off select tools
LG GS170 Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
89
All Time:
1,059
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing a dead or dying battery in LG GS170 cell phone.
    1. LG GS170 Battery Replacement, Back Cover: step 1, image 1 of 3 LG GS170 Battery Replacement, Back Cover: step 1, image 2 of 3 LG GS170 Battery Replacement, Back Cover: step 1, image 3 of 3
      • Turn off the the cell phone.
      • Locate the the arrow at the top of the back cover.
      • Slide the cover downward until the cover comes off.
      Ask FixBot
    2. LG GS170 Battery Replacement, Battery: step 2, image 1 of 3 LG GS170 Battery Replacement, Battery: step 2, image 2 of 3 LG GS170 Battery Replacement, Battery: step 2, image 3 of 3
      • Completely remove the back cover, and the battery should be visible.
      • Locate the gap at the bottom right.
      • Use your thumb to pop out the battery.
      Ask FixBot
    3. LG GS170 Battery Replacement: step 3, image 1 of 1
      • The battery can be easily removed once it's lose. The ID tag should be visible after the battery is removed.
      • Be careful of damaged battery. Inspect the battery for crack, rupture of the plastic, excessive leaking, or discoloration. Remove the battery carefully if it appears damaged.
      Ask FixBot
Author
with
Minna
101 Reputation
1 Guide authored
USF Tampa, Team 1-25, Donnelly Fall 2014 Member of USF Tampa, Team 1-25, Donnelly Fall 2014
USFT-DONNELLY-F14S1G25
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 89
All Time: 1,059
